Replacing Batteries
19,427
5
38
My 23' is not an ideal battery hauler. Since there's no place for them in
the rear, they have to ride up front. I use a 3-battery Ragusa aluminum
tray at the right front. That's very convenient for carriage, but NOT for
maintenance. With other mods I've done in that area, it's might' nigh
impossible to R&R the 2 golf cart batteries and completely impossible to
R&R the chassis battery without removing those two. Checking the water in
the golf cart batteries is difficult; in the chassis battery, might' nigh
impossible -- only possible with a mirror to check levels.
So, over the years I've developed a way to remove them through the wheel
well with the tire removed. WIth the inner 1/2 of the wheel well liner
left out
(http://www.gmcmhphotos.com/photos/g3609-2-piece-wheel-well-liner.html),
as I've run for many years, there is a way: A simple ramp from the back of
the battery tray to the top suspension A-arm gives me an easy way to get
each battery slid into a sort-of-manageable position. I was able to remove
all 3 last week without dropping one or taking a sulfuric acid bath.
Putting batteries back in isn't nearly as easy because the HEAVY batteries
don't slide uphill nearly as easily as downhill. So, a couple of years ago
I devised a battery lift for putting them back in (I'll probably have to
learn to use it for removal too for the next cycle). Here's an album
showing the lift and how it works in case anyone has a similar problem.
Granted, without a lift or ramp, as I have, redesign will be necessary --
maybe using a transmission jack? Or even a regular floor jack?
https://photos.app.goo.gl/yk4CDKzsfUIWteGw1
Ken,
I'd suggest:
For the 12VDC battery ($28.39): https://www.rvupgradestore.com/Single-Battery-Watering-System-p/55-8755.htm
For the two 6VDC batteries ($44.84): https://www.rvupgradestore.com/RV-Battery-Watering-System-p/55-8752.htm
Hand Pump ($18.03): https://www.rvupgradestore.com/Flow-Rite-Hand-Pump-p/55-8753.htm
Total: $91.26 plus shipping.
Bottom line: for a hundred bucks you won't have to remove them to service them. BTW I have the same setup up front on Double Trouble
and have been happy with it for YEARS! Sorry no photos.
However, I have the same setup on the two 6 VDC batteries under the bed on the drivers side.
http://www.gmcmhphotos.com/photos/xantrex-inverter-installation/p56751-xantrex-2-a.html
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ken Henderson
Sent: Tuesday, December 5, 2017 8:53 PM
To: GMC Mail List
Subject: [GMCnet] Replacing Batteries
left out
I hopefully have no more needs to maintain and/or replace the house
battery in my 23' - I went ahead and bought LiFePo4 batteries. Mighty
expensive initial investment at around 8-10x the price of my old
batteries, but with two, for me, big advantages: No maintenance needed,
and you can put them anywhere *inside* the coach. Which is helpful in
the 23'.
Best regards
Peer Oliver Schmidt
PGP Key ID: 0x83E1C2EA
'76a Eleganza II 26', VA
'73 Sequoia 23', Germany, SH
Rob,
Those are exactly what I installed last week. I didn't find prices quite
that good, but wish I'd spent the money 15 years ago! :-)
On Tue, Dec 5, 2017 at 11:33 PM, Rob Mueller
wrote:
> Ken,
> I'd suggest:
> the drivers side.
Peer,
I'd like to hear more about your LiFePo4 battery installation. Did you need to replace your converter/charger? or could you modify it for LiFePo4
battery charging. Also how did you handle the engine charging alternator to make it compatible? or did you just disconnect the engine charging.
I'm leaning towards LiFePo4.
Bruce Hislop
ON Canada
Hubler 1 ton front end
I cheated.
My coach had a 4D and a Grp27 engine battery. All were on a rotted wood support. As I had to rebuild it, went with a pair of GC2s that are in front
where they can be tended, and a Grp25 engine battery is aft of them and quite in accessible, but it is service-proof, so who cares. When I put them
in, I could actually life the GC2 out the front hatch. That was then, this is now. Not happenin, so I took the page from ken and a 2x6 and slid them
all out to the top of the tire. Still a bear.
If Mary hits to lottery, maybe so new technology. Until then, we are stuck with lead.
> I cheated.
> them
> stuck with lead.
> Matt
Bruce Hislop schrieb/wrote
> Peer,
The batteries are on order, leaving CZ today, and should arrive her in
Germland by next week. I have a new charger/inverter (Victron Energy
MultiPlus 30-2000-80 (already in) plus a Lynx VE.can in a week or so),
but the batteries themselves have a BMS installed. At the moment, my
plan is to keep the existing charging in place, ie. keep the engine
charging alternator connected.
https://www.ev-power.eu/Winston-40Ah-200Ah/12V-2-4kW-LiFePO4-yacht-set-with-200Ah-cells-BMS-mobile-monitoring.html?cur=1
is the battery I got, in case someone wonders.
Best regards
Peer Oliver Schmidt
