Darren wrote: The 317 is a continuous duty pump. It can run all the
time if it needs to.
The 315 is a 120 psi pump and the 317 is a 150 psi pump.
Jack,
What Darren wrote is accurate. I have the 317 which is necessary if
you switch to a 4-bagger system. The 4-bagger comes with instructions
that tell you to set the pressure control switch to 130 lbs.
HTH,
Steve
Jack,
HTH,
Steve
