I just spent the last couple of days reading on here and found a lot of info and went out on a lot of off topic trips. But I can not find out if I can
fix or repair one of the control arms. The passenger side control will not stop venting the air out. This of course causes the bag to deflate and over
night the drivers side will also deflate. I do have the shut offs and did drive home with the bags held at "ride height" but I don't see how those of
you that do this on a regular basis enjoy driving at all. On the back country roads I had to drive on it made the motorhome feel like a top heavy
bread truck.
Anyway already off topic, can I repair the vent on the height control arm or is the only fix replacement?
And Yes I took the nut off the end and made sure the little schrader valve was working. Whatever pushes on that is not releasing. I did not take it
off the Motorhome to look in. We were replacing the air bag in campground and did not want to take too much apart.
Adam Raeburn
Rothesay, NB
1976 Austin Mini
1977 GMC Palm Beach
Once you replace everything that is attached to something else. It will all be fixed.
bread truck.
Adam Raeburn
Rothesay, NB
1976 Austin Mini
1977 GMC Palm Beach
