> Wally,
> Thanks for the picture of Bob's 1332 project. He's told me about it so I
> had an idea of what he's done, but hadn't actually seen it yet. When you
> talk to him, ask if he considered a master-slave hydraulic linkage rather
> than all that mechanical paraphernalia. I remember looking at an old Dodge
> dump truck with a Hydroboost located on the frame below the cab. At the
> firewall there was a simple single-piston master cylinder; that was plumbed
> to a simple single-piston slave cylinder whose output drove the
> Hydroboost. Simple and effective and VERY easy to design and build.
> Should work well for us and never develop play like the mechanical linkage
> will. I haven't looked for the master-slave hydraulics, but it should be
> readily available.
> Ken H.
> >> Guys,
> >> Just thinking out loud to many of you other thinkers, if there was a
> > master cylinder for 6 wheel disk brakes which would perform much better or
> > as
> >> desired, but would not fit due to too large a reservoir? If so, one
> > could possibly reduce the reservoir height (if metal), make a semi permanent
> >> cover and make the balance of the reservoir remote.
> >> Simply, not re-engineer a Master Cylinder, just modify the reservoir or
> > move it to fit.
> >> Is there such a Master Cylinder which is best or better, but is just too
> > high?
> >> Thanks,
> >> Tom K.
> > We had these fitted and a picture of Bob Stone's 1332 project
http://www.gmcmhphotos.com/photos/g7378-40-mm-master-reservoirs.html
> > Wally Anderson
> > Omaha NE
> > 75 Glenbrook
> > Megasquirt EFI Onan & 455
> > Bosch Hydromax
> > Manny reaction arm system
> > Kelsey Hayes park brake
http://wallyandsue.blogspot.com/
Stone did consider a remote hydraulic actuated system and there are several available from others already. Hal StClair is looking at it too for his
FMC, yes thats FMC not GMC.
https://www.tdsideas.com/store/p1/Remote_Hydroboost_Mounting_Kit.html
https://bustedknuckleoffroad.com/products/remote-mount-hydroboost-brake-kit
https://www.vancopbs.com/product_p/urs.htm
Wally Anderson
Omaha NE
75 Glenbrook
Bosch Hydromax
