I am going to rejet my Qjet. Since the engine rebuild the engine has
been running somewhat warmer at high speed than before. At idle it
drops real quick back to 160 or so. Running at 70-75 it was around 190
and up to 215 on the hills. It has a good hi volume water pump, good
fan clutch and new balanced flow thermostat. Checked plugs after an
extended 70 mph run and they read lean. I am assumeing the lean
condition is the reason for the higher temps.
The new engine has the RV cam, and the heads were redone and it has
headers. How hard or easy is it to change jets. I assume I will go up
two sizes and if it is running rich then back it down one size. The
carb has 73's, IIRC, in now.
Any suggestions from the Qjet wizards.
Marcus
Marcus
