Refrigerators
patrick flowers
1,460
> Are you using the original fridge? If so, the draw is pretty high. I
> measured it last summer but don't remember the draw (about 25 amps I think).
> I've gone to a 3-way fridge to extend boondocking and allow me to keep
> things cool using the alternator output.
I'm planning to replace my fridge also, but I don't want to mess with
plumbing the LP. After some research, I settled on the Norcold DE-461,
which is a 120VAC/12VDC model with a 12 volt compressor. According to
Norcold, it only draws 5amps on 12 volts. Well, my father called a
couple weeks ago telling me his original fridge had died and asking
which one I had been talking about. We ordered him a DE-461 and, with
the exception of removing a small trim strip, it slid right in the hole
and works much better than the old factory fridge.
If you want to go this route, don't let anyone sell you a DE-561 because
that's old stock. I've confirmed with Norcold that the DE-461 is the
newer model(don't know why they went to a lower number on the newer
model) with a compressor that's approx. 20% more efficient and dual
cooling fans.
Patrick
It is because all of the control boards that are the supposed brains of the unit
run on 12v power. So, even if you have 110 you still need 12v to work the
board. Darren
> In a message dated 6/10/99 12:47:20 PM Central Daylight Time, patri63
> Norcold, it only draws 5amps on 12 volts. >>
> Now, will someone explain to me why it won't work without 12vdc power, even
> on
> 110vac ??? Try disconnecting your battery cables and see if it works.
> Lanier
