Refrigerators anyone using solely electric, or what doeseveryone suggest
tom warner
113
Thanks emory what model did you get and where did you purchase it?
>www.rvmobile.com/refers/461r.htm)
>2. Or a 110V/12V/LP like a Norcold Rm 3663, RM
>3863.(www.rvmobile.com/refers/3662R.htm)
>What is the consensus of using any of them. Has anyone installed one of the
>Nova Kool refrigerators? >>
>Tom - I put in a Norcold 3 way about 6 years ago and find that I have never
>used the 12 v. It doesn't use much propane and I just set it on automatic.
>When plugged into 120 v. it switches over automatically and when I unplug it
>the gas lights.
>The 12 v. heating elements are less wattage than the 120 v. ones so the 12
>volt will not cool it down. It is meant to try to hold the temperature but
>the little bit I tried to use it, especially in hot weather, proved to me
>that it wasn't usable. I am aware that you could purchase a higher wattage
>element (equal to the 120 v. one) but then you'd have to install heavier 12
>v. wiring. The only reason that I could see to even considering this would
>be in the case of paranoia about having the propane tank open when going down
>the road.
>I would go with the two way refrig. 120 v. and Propane.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Tom & Marg Warner
1976 GMC Palmbeach TZE 166V100496
1987 Corvette hardtop
1984 Mercedes 300D Sedan
1988 Mercedes 300TE Station Wagon
1997 125 # Rottweiler, Boomer
I agree with Emery, I have a Dometic Americana Series that is AC and
propane. During the season I leave it on auto and it switch back and
forth as needed. I do shut it off when fueling.
J.R. Wright
GMC GreatLaker
Michigan
> the gas lights.
> the road.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
