Tom, The Dometic Silhouette is very comparable to our Flushmount refrigerator using the similar componets. If you are having intermintent gas outage, the first thing to do is to clean the burner and orifice. When cleaning the orifice use a solvent that does not leave a residue (carb cleaner). The Ignition electrode should be 3/16" above the burner and if it has the sensing electrode it needs to be straight out. Make sure the spark does not jump between the electrodes, that will make the ignition module go bad. The gas flame should be non-yellow and be stable. If the flame is eratic or lifting, the gas pressure may be too high. 11 inches water column is the correct pressure. Hope this helps.
Chris Black
Norcold Customer Service
- -----Original Message-----
Sent: Sunday, September 27, 1998 11:20 AM
To: GMC Motorhome List
Subject: GMC: Refrigerator Shuts Down
Our 1974 Eleganza SE has a replacement Refrigerator -- Servel by Domestic
(S530 Silhouette).
I am trying to figure out why it shuts off when I still have plenty of gas.
One the first trip, it ran for about two weeks and the "check (gas)" light
came on when it shut down. There was still plenty of gas - almost a full
tank. I filled the gas tank and when we arrived home ran the refrigerator
until it shut down again - about a week. On Saturday I filled the gas (took
$2.00) again and fired up the refrigerator. On Sunday AM the refrigerator is
still cold but it has shut down again.
Has anyone had a similar experience? Can anyone suggest a simple fix that I
may be overlooking?
Thomas P. Winslow
1977 GMC Coca-Cola TZE167V101893
1974/75 GMC Eleganza SE TZE064V101146
189 Hicks Creek Road, Troutman, NC 28166
h704-528-5868 * f704-528-5868 * p704-878-1157
E-Mail: winslow * tom_winslow
http://www.iredell.com/gmc4sale.html
- ------ =_
NextPart_000_01BDEABF.DC9446C0
Content-Type: application/ms-tnef
Content-Transfer-Encoding: base64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- ------ =_
NextPart_000_01BDEABF.DC9446C0--
