Refrigerator replacement 2026
Don Jaksa
566
383
63
I am on a roll upgrading house systems and now the 53 year old electric color-matched refrigerator is ready for a modernization
I hate to do away with the whole original theme to my coach but at some point, doing away with the old one is necessary to assure reliable service
I tested it out when I first got the coach and it cooled and froze as expected
I ran it yesterday and it started to cool but was not progressing
The previous owner had added a schlader valve to add refrigerant (propane) and the unit would probably work if I did that
Once I have the unit out, it can be serviced by a regular appliance tech if I so desire
New refrigerator:
I will need a refrigerator that will fit in the existing space...or nearly fit
The cutout appears to be 52.5" H 24" wide and reportedly 24" deep @ 52.5" high
Once I remove "Ol yellow" I can see how much space I actually have to work with
Absorption vs compressor technology:
Absorption allows the use of propane but requires venting. I would have to add the vent and plumb the gas line to the compartment. I am moving away from propane these days and going 12vdc, but I have to consider the options
Here is my leading contender for an absorption 3-way refrigerator
A beautiful appliance, three-way power
But word-on-the-street is that modern 12vdc staged compressors work really well, even in hot weather and do not require venting
I looked at a lot of contenders but size was the biggest determining factor for selection
Here is the leading contender for 12vdc refrigerator
I can't wait to pull the fridge out and clean out the space
I will also insulate the compartment like others have suggested
Any suggestions?
New refrigerator:
Any suggestions?
Check out the Indel Combi CR195 refrigeration/freezer that is detailed in my post. It only is supposed to be using 680 watts per day for the refrigerator/freexer and 35% less if you add the compressor controller. You can purchase an optional trim from them so that you can insert a panel that matches your cabinetry.
See #286 on page 15 of Converting to LiFePO4 batteries and Sailor Man's LiFePO4 Build. The 2023 pricing is in post #291. This pricing is for the stainless steel version. The version for your panel is considerably less.
I know that it is pricy but it will pay for itself in the significant reduction in energy costs and repairs. This is a very high quality product that is designed for the rugged marine world.
The Indel 195 combo will fit for the required dimensions
Dimensions (cut-out): 52.9" H x 21.4" W x 22.5" D
Ouch! Kinda out of my price range @ $2800
After pricing and quotes for shipping costs of new units, repair looks like a viable option (in my price range)
I have watched videos of people servicing this exact unit.
The current refrigerator already is 12/110 volt
I couldn't justify $2,000 for a new fridge when my OEM all-electric Norcold died. So I bought a 7.5Cu.Ft apartment size fridge for under $400 Cdn. It's 120VAC, but I already had the inverter. Since then I've upgraded the inverter to a Samlex Inverter/charger/Transfer switch and installed 200AmpHr of LiFePO4 batteries. I also put a 175W solar panel on the roof. I'm still under the original $2k total cost. The solar panel keeps up with the fridge on a sunny day.
The new fridge has been working great for 12 years now.
Reactions: Don Jaksa
REMOVING THE UNIT:
There is a hinge pin/flathead screw on the top of the freezer door and the bottom of the refrigerator door. Remove these and the doors come off
There are four screws holding the unit in place
It seems like the base was stuck to the floor and I had to coax it to break free
I think I'll get my transmission jack out and see if it can be of some use in removing the unit
New refrigerator:
Any suggestions?
Hi Don,
I have my refrigerator replacement documented in my build thread, here for reference:
Maybe it will be of some help in your decision,
Todd
What a headache for a direct-drop-in replacement.
How many times did you have to put it in-take it out? The exterior vent shroud should have helped.
The final product looks pretty good and it works, so win win
Yeah, the NA7XLR is a electric/gas absorption refrigerator
The Norcold N8DCBKR is strictly 12vdc compressor refrigerator
less hardware, no venting
I read your thread and was concerned because the dimensions seemed the same as the one I am pondering but my cabinetry is early and not so dovetailed
The curve in the back of the refrigerator compartment is always trouble
The original refrigerator is already to come out now
Just power the coach down and heave-ho
I'm not familiar with RV DC compressor refrigerators. A refrigerator is a heat pump regardless of where the BTUs come from, and there'll be a fair amount of heat being produced to achieve the cold. When you say no venting does that mean that it can be installed with no openings to the exterior and the only air exchange is to the interior?
I see too many coaches that don't have the back baffle just exterior to the refrigerator fins, and are not channeling the rising air directly over the fins. Not directing the air is shooting the refrigerator in it's foot.
I don't know if it's changed but the specific Dometic installation manual for my specific refrigerator that came with it 8 or 10 years ago did not mention the maximum clearance between the fins and the back baffle, but the generic Dometic instructions for all of their refrigerators did. Pissed me off big time.
Maximum clearance from the fins to the back baffle is an inch or less. Very important for efficient heat transfer.
New refrigerator:
Any suggestions?
It depends on your intended usage. If you intend to do any dry camping, you may want to go with an absorption refrigerator as it will use MUCH less electricity than any compressor type. They also SIP propane. If you have enough solar to keep up with the demand, AND recharge your batteries, or if you will always be plugged in to shore power, then a compressor type will not be a problem for you.
