Refrig replacement or keep discussion
That link was wrong. Here is the correct one:
http://www.gmcmhphotos.com/photos/g4826-refrigerator-compartment-insulation-26amp-3b-baffle.html http://www.gmcmhphotos.com/photos/g4826-refrigerator-compartment-insulation-26amp-3b-baffle.html
Emery Stora
77 Kingsley
Frederick, CO
> Begin forwarded message:
> From: Emery Stora
> Subject: Re: [GMCnet] Refrig replacement or keep discussion
> Date: January 28, 2017 at 11:22:57 AM MST
> To: gmclist
> Reply-To: gmclist
> GM handled this problem by using a wooden baffle that leads down from the bottom of the outside door to just below the bottom cooling fins.
> Some GMC motorhomes are missing this baffle.
> You can see pictures of my install here:
> http://www.gmcmhphotos.com/photos/macerator-and-storage-for-hose/p3556.html http://www.gmcmhphotos.com/photos/macerator-and-storage-for-hose/p3556.html
> There is a picture of the baffle included.
> I also show GM’s original drawing of the compartment and baffle.
> With the baffle you can use a Norcold or a Dometic and they both work well. The upward draft through the roof vent will pull in air through the side vent and it will flow downward to below the fins.
> I have a couple of 1” holes drilled in the floor of my refrigerator compartment covered with screening. These holes will allow propane to drain out in case there is a leak as propane is heavier than air.
> Emery Stora
> 77 Kingsley
> Frederick, CO
>> Exactly!! And the bottom of that vent must be at or below the bottom of
>> the fridge compartment. I don't think it's possible to do that, due to
>> the wheel well location directly below the compartment.
>> I didn't note the year of "Gatsby's Cruiser" when I replied, but on the
>> coaches I've noticed with an outside access door, they were all in about
>> the same location as mine. The bottom of the vent is considerably above
>> the bottom of the fridge compartment. In my case it was 10", and Norcold
>> said, "No warranty because vent placement not as required". Wording not
>> exact, but close.
>> ron
>> On Wed, 25 Jan 2017 13:17:00 -0700 Jon Roche
>>> JR.
>>> I believe Ron is correct, the issue is not that the GMC motorhomes
>>> do not have a vent behind the fridge, but the location for that
>>> vent in
>>> relationship to the bottom of the fridge.
>>> Usually the GMC fridge bottom sits right on the wheel well, and
>>> that is about 6" lower then the beltline of the GMC, and lower than
>>> the opening of
>>> the vent.
>>> as seen in this picture:
>> https://4.bp.blogspot.com/-TgcwcpeczmA/VvrbM31qFNI/AAAAAAAAT18/SPJoImrN0X
>> AF0rM6uWd24p0MWxnUkgXAg/s1600/IMG_4266.JPG
>>> The Norcold installation instructions states that the vent is to be
>>> even with the bottom of the fridge. Not really an option in our
>>> coaches.
>>> page 4:
>> http://www.thetford.com/wp-content/uploads/2015/04/1309/Installation-Manu
>> al-Through-71904.pdf
>>> it really has no instructions as to what do do if the vent is not
>>> even with the bottom of the fridge, and I think that is where RonC
>>> had issues with
>>> the warantee. It is not installed per there instructions.
>>> Dometic on the other hand, does not list that as an absolute.
>>> there is a minimum venting height, in the case of the rm2652 it is
>>> 57 1/2" from the
>>> bottom of the lower vent to the roof vent.
>>> I have the manuals for Dometic at home, it is confusing, because i
>>> think they have a few different hard to find installation manuals
>>> that has
>>> additional information then the "operating and install manual" that
>>> is easy to google and find. They also have some ventilation
>>> manuals.
>>> the reason that norcold states the vent needs to be at the bottom,
>>> is stated for the propane to be able to vent out, so either way, a
>>> vent at the
>>> lowest portion of the fridge enclosure is important. I used a
>>> simple shower drain on mine.
>>> Jon Roche
>>> 75 palm beach
>>> St. Cloud, MN
>>> http://lqqkatjon.blogspot.com/
>>> ___________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
>>> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
>> Ron & Linda Clark
>> North Plains, ORYGUN
>> 78 Eleganza II
>> _______________________________________________
>> GMCnet mailing list
I know that now, Jon, and I have already reposted the message with the correct link.
It is http://www.gmcmhphotos.com/photos/g4826-refrigerator-compartment-insulation-26amp-3b-baffle.html http://www.gmcmhphotos.com/photos/g4826-refrigerator-compartment-insulation-26amp-3b-baffle.html
Emery Stora
> Emery,
> Which picture shows the baffle, pictures posted show the macerator installation of the hose.
> J.R.
>> Emery Stora
>> 77 Kingsley
>> Frederick, CO
>>> exact, but close.
>>> ron
>>>> JR.
>>>> vent in
>>>> the opening of
>>>> the vent.
>>>> coaches.
>>>> page 4:
>>>> had issues with
>>>> 57 1/2" from the
>>>> that has
>>>> manuals.
>>>> vent at the
>>>> Jon Roche
>>>> 75 palm beach
>>>> St. Cloud, MN
>>>> GMCnet mailing list
>>> Ron & Linda Clark
>>> 78 Eleganza II
>>> GMCnet mailing list
>> GMCnet mailing list
On my '76 Birchaven, the wheel well liners have a vertical extension which
leaves a gap between the outer body and that extension. In the
refrigerator compartment I drilled from the inside, through the liner
extension, into that gap. Screen wire over those holes prevents critters
from coming in and stored junk from falling out; the vertical gap does not
allow water and debris from the rotating wheels direct access to the holes
-- I never have anything entering the refrigerator compartment from there.
It might not satisfy Norcold, but it does provide an exit for any leaking
LPG, and the baffling I've also installed ensures adequate cooling air flow.
Americus, GA
www.gmcwipersetc.com
> exact, but close.
> ron
