This is the ad. JUST COMPLETED restoration. Bought it to fix up for o=
ur daughters family. Then a medical issue came up for her. Pl. Sell. =
This 73 Canyonland has just had the entire interior removed, refinished =
as needed, and reinstalled. Cabinets, and drawers have been reassembled w=
ith glue, and screws for durability. Interior of closet drawers have been=
sanded. And a coat of clear urethane applied for a clean surface. The cl=
oset had been lined with Cedar. New modern looking counter top. New plywo=
od ceiling that has a mold, and mildew resistant coating applies to both t=
op, and bottom sides. Real Walnut paneling installed from the door forward=
. A high end cloth headliner that is used in custom built Winnebago motorh=
omes has been installed. With 8 LED recessed lights. These lights are cont=
rolled by wall switches. Bed area, and hall lights can be turned on at fron=
t door. Then turned off from rear bed. All new under cabinet lights are LED=
's. Two Fantastic ceiling vents units in ceiling. One is new. TV coax cable=
, and USB ports installed at front, center, and rear of couch. Newest in e=
lectronic 110 volt to 12 volt converter installed. More 110 volt plugs adde=
d. New window treatments. $2,400 spent on all cushion/seats. New flooring=
. Built in micro wave cabinet. These next items are also new. Roof A/=
C unit, Magic Chief 4 burner cook top, Domedic frig/freezer, Sur flow wat=
er pump, and a replacement Suburban furnace. These appliances where replace=
d at a cost of $2900. Outside paint is older. But nice. Mechanicals.=
New 16" American Eagle rims. With Dunlop tires. 6 new KYB shocks. Both ga=
s tanks flushed, and installed with new gas tank sending units. With new ru=
bber gas line. New exhaust tail pipe. Complete 78 rear suspention, and bra=
kes installed. All brake hoses replaced for safety. Main frame is in excell=
ent condition. Cleaned, and painted. Engine oil pressure is good. Compressi=
on readings are excellent. At 150 to 155 psi. All belts are new. New=
cam timing chain/sprockets, engine water pump, and front brake hoses/cali=
per and brake pads. Carburetor rebuilt. New ignition points, plug wires, a=
nd spark plugs. This GMC will be able to travel anywhere in the country.$1=
8,000. I taught Industrial Arts auto/woodworking. Been into GMC's since 200=
3. I've rebuilt 3 GMC's before this one. One for a close friend. And 2 diff=
erent ones for our personal use. Bob Dunahugh 319-521-4891 YENKO108=
t mail.comhttp://mail.com
