I can recommend an expansion tank for your water system. I suggest the 2
gallon size and it will give you the best service possible and what I use.
Go to Ace Hardware, Lowes, Home Depot and do a search for expansion tank
and several will pop up at each site. They typically run in the $38 to
$42 +/-. DO NOT get the little black plastic 1 qt expansion that is
available from many RV supply places. I had that in our first coach and it
was almost not noticeable, not worth he price, almost the same price of a 2
gallon unit.
https://www.campingworld.com/shurflo-accumulator-tank-2290.html?cgid=fresh-water-pumps-accessories=12&cgid=maintain-your-rv%2Ffresh-water%2Ffresh-water-pumps-accessories
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 29.5' Stretch
On Sat, Nov 9, 2019 at 11:21 AM John Shutzbaugh via Gmclist <
> On our 77 Eleganza I was able to fit a 2 gallon (or maybe only one gallon)
> tank vertically just aft of the water tank. The tanks are available at
> Home Depot, Lowes, etc. It just barely fits, and for access one needs to
> take off the deck on which the curbside dinette sat or sits if you still
> have it. It is not easy working in that space, but I think it's worth it
> as you can get 2-3 flushes and hand washes before the pump cycles. I
> charge the bladder with 20 psig air when empty.
> I agree with Matt, I like hearing that pump as an alarm if we aren't using
> water.
> John S.
> John Shutzbaugh, Vacaville, CA, ncserv;
> 77 Eleganza, bought it new, can't blame PO; and
> 78 Buskirk stretch, "What were we thinking?"
