Rear Window
paul bartz1
1,638
Thanks to "friends of the night", last Saturday morning I discovered that a flat,
limestone, triangular rock, about three inches on a side, had been thrown through
the rear window of my 78 Royale. The rock punched a softball sized hole through
the glass, penetrated the shade fabric, put a couple dents in the corner of the
wardrobe woodwork, and landed on the floor in front of the hutch adjacent to the
side door. Needless to say, the glass, which is tempered, broke into a million
pieces and would have fallen to the ground except for being restrained by the
window tinting film I had installed.
Thanks to Max Pardy of Buskirk Rush RV, a customer (Branko Horvat) on his way back
to Deerfield IL, on the NW side of Chicago, delivered a replacement glass to me
this afternoon. His comment upon arrival was something to the effect that "this
is what you should do for a fellow GMC owner". What service!
A local glass company arrived a short time later and had the old out and the
replacement in in less than 20 minutes.
Remember the previous discussion about the ring on the interior of the coach,
above the rear window, which serves as the emergency escape release device???
Previously, I was not knowledgeable of its modus operandi. All there is to it is
the circular opening in the bottom of it, is threaded through the rubber spline
that goes around the perimeter of the glass rubber gasket. Pull the exposed loop
and you pull out the spline, but you need to pull it out all the way around the
glass. You can then push out the glass.
So if you have blinds, curtains, shades, etc., particularly the boxed-in kind (e.
g. valence), covering up the ring, it may be difficult to get to the ring.
Incidentally, the rear window glass is not very heavy and a single individual can
easily pick it up and carry it around.
By the way, insurance is taking care of the damage expense.
Paul Bartz
Couldn't be any better, Jim.
Paul Bartz
[mailto:owner-gmcmotorhome]On Behalf Of GMC73CL
Sent: Wednesday, July 12, 2000 5:39 PM
Paul,
Sorry about your back glass but happy to hear about your incredible luck in
getting a replacement and getting it back in so quickly. Makes you feel real
proud of these GMC people doesn't it?
Sorry to hear about your visit by the "friends of the night". Glad to hear it all
worked out. It is amazing how fellow GMCers will help out. I remember a night about
10 months ago when this guy from Kalamazoo spotted me broken down on the side of I-74
named Paul Bartz. He helped me out, and I had been an owner for less than 12 hours!
Maybe the GMCer delivering your glass was partial payback.
Ron and Julie
73 Painted Desert
> Paul Bartz
Thanks gentlemen, for the kind words.
Incidentally, it is the rubber spline that is threaded through the base of the
ring and not the way I originally said it below.
Paul
[mailto:owner-gmcmotorhome]On Behalf Of JRMEEKHOF
Sent: Wednesday, July 12, 2000 10:02 PM
In a message dated 7/12/00 7:07:40 PM Eastern Daylight Time, rkazi
writes:
a flat,
through
through
of the
to the
million
the
way back
to me
"this
the
coach,
device???
to it is
spline
exposed loop
around the
kind (e.
individual can
> Paul Bartz
I think the quick service is a result of the GMC gods showing favour. It is
understandable, just look how Paul takes a bad experience and gleans as much
information as possible from it for the benefit of his fellow GMCers. Paul,
you deserve the very best!
Dave
73 GoBus 230
>to hear it all
>the side of I-74
>less than 12 hours!
>Ron and Julie
>73 Painted Desert
I also remember Paul Bartz taking time off from work last year in
June and driving about 100 or so miles trying to get me some help
when my engine spun a rod bearing on I94 by Jackson just a couple of
miles from Tim Brown's Gilberts resturant.
He is quite a guy! Sounds as if he is making a habit of his road service help!
When I lived in Michigan I had belonged to an FMCA chapter called the
Knights of the Highway. I don't know if Paul is a member of that
group but he certainly is a White Knight!
Thanks again Paul.
Emery Stora
77 Kingsley
Santa Fe, NM
My pleasure, Emery.
Paul
[mailto:owner-gmcmotorhome]On Behalf Of Emery L. Stora
Sent: Wednesday, July 12, 2000 10:43 PM
>to hear it all
>the side of I-74
>less than 12 hours!
>Ron and Julie
>73 Painted Desert
> Makes you feel real
Gotta concur.
I'm on several lists for info of various sorts, but this GMC net is more
like a fraternity.
Fritz Washburn
77 kingsley
Twin Citties
On Wed, 12 Jul 2000 17:04:29 -0400 "Paul Bartz"
writes:
> that a flat,
> thrown through
> Paul Bartz
> Sounds like a happy ending to a sad beginning! Glass delivery
arrangements couldn't have been better.
David Lee Greenberg
The GMC Motorhome Registry
Dedicated To The Preservation of the Classic GMC Motorhome
http://www.GMCss.com/Registry.htm
http://www.Buskirk-RushRV/GMC-Registry/online-registry.htm
