I have an issue with the rear ride height the right rear is about 1 inch lower than the left rear when you set the Electro-Level to auto.
I can correct it by setting to hold and adjust it manually but I would rather have the auto function work as it should and not have to pull out the
tape measure all the time. Everything appears to be ok in both wheel wells and I do not have adjustable links.
Is it as simple as getting adjustable links and install them, and then adjust them to get the coach sitting right?
Or am I missing something that could be a problem?
Looking for any thought on this.
Tom Lins
St Augustine, FL
77 GM Rear Twin, Dry Bath, 455, FI-Tech EFI
Manuals on DVD
http://www.bdub.net/tomlins/
Tom Lins
St Augustine, FL
Manuals on DVD
