Rear drums
dean hanson
256
Any suggestions on how to make a tough job easier? I would like to add
'holes' in the back of the drums to adjust my rear brakes.
Ideas please.
Dean C. Hanson 75 Avion coming back to life.
P.O.Box 2096
Fremont, Ca. 94536
(510) 657-9600
There are knockouts in the backing plates for that. Just punch them out with a hammer and an old screwdriver or punch and there they are. You can
buy rubber plugs to close them up with again.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
If the knock-outs are in your backing plates, just knock them out. If not,
you will have to either replace the backing plates, or compare yours to
ones with the slots, drill them and finish the slots by hand. There have
been enough disc brake conversions out there that there might be some used
backing plates out there for a reasonable price if $$$ is a problem.
On Mon, Sep 16, 2019, 9:45 AM Dean Hanson via Gmclist <
> Ideas please.
> P.O.Box 2096
> Fremont, Ca. 94536
> (510) 657-9600
I've never seen a backing plate without removable plugs for the adjuster to fit. However, if yours don't have the holes, xspeak to anyone here who
has converted to rear disks.
Correct me if I am wrong but the knock-outs in the backing plates are used
to pull the shoes inward so that drums can be removed once a grove has been
worn into the drum from the shoes. Shoes auto adjust everytime you stop
when backing up. You just have to have them pretty close when you initially
put them on.
Rich
On Tue, Sep 17, 2019 at 10:36 AM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
Most people don’t back the GMC enough and also hard enough to adjust them.
When I had drum brakes about once a month or two I used to find a large empty parking lot and get my GMC backing up at 10 mph or more and slam on the brakes. I would repeat this about 10 times and then my braking would really improve.
> put them on.
> Rich
>> --johnny
>> Braselton, Ga.
>> in hell
Not all coaches were equipped with self adjusters. Nor were they all the
same when it came to those slots. Don't know, and don't care much when
these changes occurred during production. I just look at the backing
plates. If the slots are there, so much the better. If not, I just put some
in.
On Tue, Sep 17, 2019, 9:01 AM Rich Kinas via Gmclist <
> put them on.
> Rich
> who
> > --johnny
> > Braselton, Ga.
> > in hell
James, I have never seen a GMC that was not equipped with the self adjusting rear brakes. Has anyone else here ever seen that?
Frederick CO
> in.
> Salem, Oregon
>> put them on.
>> Rich
>> who
>>> --johnny
>>> Braselton, Ga.
>>> in hell
>>> GMCnet mailing list
Like I said, I don't know where or when. I have encountered it more than
once. Don't know if it was early or late in production, and when I
encounter it, I fix it.I have never given it much thought.
Salem, Or.
On Tue, Sep 17, 2019, 9:19 AM Emery Stora via Gmclist <
> Emery Stora
> 77 Kingsley
> Frederick CO
> > On Sep 17, 2019, at 10:14 AM, James Hupy via Gmclist <
> some
> > in.
> > Jim Hupy
> > Salem, Oregon
> used
> been
> initially
> >> put them on.
> >> Rich
> adjuster
> >> who
> >>> --johnny
> >>> Braselton, Ga.
> me
> >>> in hell
> >>> GMCnet mailing list
> >> GMCnet mailing list
On more than a single occasion, I have encountered vehicles that have had the automatic adjusters removed. I advised the owner that this was not the
best plan...
I am not under the coach just now (Duh), but I am also remembering that some backing plates had two knock outs or adjuster slots. This was to
accommodate the different assembly for the two sides. I don't recall of GMCs had two choices or not.
Never saw one. The plates are different.
There were GMC shops that were pulling them off and not advising customers
of the mods.
They do work, but one need to do like what Emory mentioned in order to get
max performance .
Lack of use is again the issue.
On Wed, Sep 18, 2019 at 5:50 AM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
Every 60's GM vehicle I have worked on had self adjusting rear drums. Since this was the 70's and GM's flagship vehicle I cannot imagine they did not
all come with self adjusting rear drums. I can only think some previous "mechanic" couldn't be bothered with the " complexity" and as a rule, when
people don't understand a system, they circumvent it.
Next time I encounter a GMC motorhome that has NO SLOTS in the backing
plates, I will FOR SURE take pictures and post them on the photo site. I
didn't think that it was that unusual, apparently I was in error.
On Wed, Sep 18, 2019, 7:16 AM John R. Lebetski via Gmclist <
> not
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
I had to bust out the slots with a cold chisel in our Palm Beach. Then buy
plugs.
bdub
On Wed, Sep 18, 2019, 9:47 AM James Hupy via Gmclist <
> Salem, Oregon
> did
> > not
> when
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
