>After reading all of the good advice on the permanent rear bed conversion,
>and taking into consideration how I use the coach, here is my plan.
>I intend to build a box over the top of each of the side areas. These boxes
>will be 7" tall (ripped 1x8) to provide a net 6.25" of vertical storage on
>each side.
Before you start, get your coach level. I used a 6' builder's level to make
certain I was level fore-aft and side to side. Next, check the height and
level of the two side enclosures. I didn't do this last step when I built
mine, and discovered a half inch difference from one side to the other.
This can throw off your plans a bit.
Good luck,
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
>each side.
Good luck,
Henry
fax: (831) 462-5198
