Gary:
According to Managing 12 Volts, by Harold Barre, he says that charging
voltage above 14.1 v at 68 deg F, damages gel type batteries due to gassing.
Another interesting claim in his book for gel cell batteries is that they
are not as sensitive to the effects of repeated deep discharge and will
recover 100 percent if left deeply discharged for up to a month.
All this is contained on p 46 of his book.
On p 47, he says "for someone who wants batteries that do not give off
hazardous fumes, require no maintenance and charge more quickly than wet
cell batteries, gel cells may be a good buy."
Paul Bartz
Sent: Tuesday, May 04, 1999 3:09 PM
Subject: Re: GMC: Rear battery
Don't forget to consider the more stringent charging controls required on
gel batteries. Before you buy check out the latest issue of HIGHWAYS (the
Good Sam magazine) for a very thorough comparison of battery types, life,
care, and cost. I'll stick with 2 golf cart batteries.
John:
Looking at JEG'S catalog, a deep cycle Optima brand gel type battery is
~$180.00, regular kind is ~$140.00. So yes they are more expensive.
However, as I see it, they eliminate problems you are trying to deal with,
so there is a slight price to pay. Perhaps some of that cost can be
recouped if they have a longer life span??
Sent: Tuesday, May 04, 1999 5:16 PM
If you use a gel type battery, doesn't that negate the water adding,
I think you are right Paul, but then, would I not, have the problem of no
money left to buy gas, or do anything? They are still very expensive, no?
Money is still an object with me.... But maybe the cost is coming down and
that will be the best solution.
