Rear air suspension question....things just arent adding up.
6cuda6
945
163
43
59
Ontario, Canada
So been working on the rear air suspension of my Electro Level 1 system because i accidently dropped the right side (well i just tried the
switch....it dumped the whole bag in a split second) and it wont refill.
I replaced the DANA compressor with a known good one because mine was weak along with a faulty check valve and pressure gauge. Got it all back
together and still no lift....right side doesnt build pressure but the left side doesnt.
So i hit "travel mode" to see what would happen....i assumed the bags would balance left/right but nope....right side stayed the same and so did left
with no visible pressure increase on gauge.
All solinoids have power and click.....right side raise solenoid (one with blue line) works and allows air when i blow in it....lower solenoid (middle
of the three) allows air to flow when i blow in it....the last solinoid works(one with yellow line) but i cant verify air passage because i have
remove a bunch of other stuff in the way.....
So heres my thought on this.....one would suspect the bag or line to the bag as having a leak because the gauge never builds pressure (right side or
travel mode) but there is zero audible air leakage....which would leave me, you would think with a plugged solinoid but that would build pressure,
which it doesnt.
The other question i have is how much air should be coming out of the system at the solinoids? I would think enough that if you plugged the hole with
your thumb you'd feel it.....no?
Rich Mondor,
Brockville, ON
77 Hughes 2600
Build up air on the good side,keep the middle switch on Hold,
Then immediately put Raise on weak side as now you have pressure in tank
that will dump to the weak side
On Mon, Jul 29, 2019 at 7:22 PM tonka6cuda6--- via Gmclist <
> left side doesnt.
> left
> which it doesnt.
> with
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
> left with no visible pressure increase on gauge.
> (middle of the three) allows air to flow when i blow in it....the last solinoid works(one with yellow line) but i cant verify air passage because i
> have remove a bunch of other stuff in the way.....
> or travel mode) but there is zero audible air leakage....which would leave me, you would think with a plugged solinoid but that would build
> pressure, which it doesnt.
> with your thumb you'd feel it.....no?
Rich,
Yes, if you disconnect the line that goes to an airspring(bag) and that side is switched to "Raise", then there should be significant pressure at that
port.
Or, if it is switched to "Travel" and that side is down, then the height control valve should be supplying about that same pressure.
Are these still the OE Airsprings (bags)??
One know issue with the Sully system is the air port of the spring can get blocked when the suspension is flat.
The system is controlled by the ride height control valves in each rear wheel well. Do not expect one side to react to the state of the other.
The blocking of the air inlet port on a flat Sully Bag had never come to my
attention until recently when we became involved with a stranded GMCer
nearby. My son "rescued" the coach and had to jack up the flat side to get
air into the bag.
Has anyone devised a way to correct the problem? Having never seen one
myself, it's a pure WAG when I guess that the simple act of grinding a
groove across the area where the bag rests when flat might provide a path
for the air to sneak past. Seems to me that, or a better solution should
always be applied before the bags are installed. Huh?
On Tue, Jul 30, 2019 at 9:34 AM Matt Colie via Gmclist <
> left side doesnt.
> Rich,
> that
> port.
> Matt
> > did left with no visible pressure increase on gauge.
> > i have remove a bunch of other stuff in the way.....
> > side or travel mode) but there is zero audible air leakage....which would leave me, you would think with a plugged solinoid but that would build
> > hole with your thumb you'd feel it.....no?
> Rich,
> that port.
> Matt
OE style Firestones...which are weathered but appear to be holding air well enough to drive the coach back 700 miles from were we bought it.
Rich Mondor,
Brockville, ON
77 Hughes 2600
So i replaced another cracked fitting, which is neither here nor there at this point.
I reassembled everything and tried Jim's trick but not good enough so i got fed up and added a schrader valve to the pressure tank and went a grabbed
my portable compressor....aired up real nice....lol.
So i guess the ticket is going to be a new Viair compressor and no more DANA as it just doesnt seem to put out the volume necessary without really
working super hard and/or forever it seems.
Rich Mondor,
Brockville, ON
77 Hughes 2600
So next question....what size Viair? 350c or 450c? I want to put in in the stock location were the DANA went.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Just disconnect the air line at the air bag. Unscrew the fitting that goes
into the air bag. Screw a Schrader valve into the air bag. Inflate to 90
psi. Drive it home. Fix it there.
On Tue, Jul 30, 2019, 12:04 PM tonka6cuda6--- via Gmclist <
> refill.
> left side doesnt.
> > Rich,
> > that port.
> > Matt
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
> > refill.
> > left side doesnt.
> >> Rich,
> >> that port.
> >> Matt
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
Actually made it home, without a bleed down....but my attempts to fix at home have basically be replca broken fittings and the DANA with another known
good one......conclusion is the compressors just havent got the b*lls to fill these things from zero nor really keep up.....hence the Viair question.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Buy the biggest air compressor you can afford.
I've never heard anyone say my compressor is too big!
so 450c or 485c is awesome
From: Gmclist on behalf of tonka6cuda6--- via Gmclist
Sent: Tuesday, July 30, 2019 2:45 PM
Cc: tonka6cuda6
Subject: Re: [GMCnet] Rear air suspension question....things just arent adding up.
> > refill.
> > left side doesnt.
> >> Rich,
> >> that port.
> >> Matt
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
Rich Mondor,
Brockville, ON
77 Hughes 2600
Rich, when the leaks are fixed the system requires verylitte air volume on the road. Once it's pressured, and there's a tank, you should get the ON
light only every now and again, and on reasonable flat road not at all. Rendering it leakless can be a challenge. Put shutoffs and Schraders on each
side, and you can still use it while you troubleshoot.
> ON light only every now and again, and on reasonable flat road not at all. Rendering it leakless can be a challenge. Put shutoffs and Schraders on
> each side, and you can still use it while you troubleshoot.
> --johnny
Will do Johnny, thanks for the tip and info.
Bags are holding fine ( been 3 days now) but gauge on tank shows "0" so there is a leak someplace still....if i had to guess its either another
cracked fitting at a solinoid or the red line union just as it comes into the left/right split at the left leveling valve.....
Rich Mondor,
Brockville, ON
77 Hughes 2600
A spray bottle of kid's 'bubble juice' is Your Friend. Or, you can disconnect and plug suspects and try to pressure it again, isolating leaks. If it
dumped all at once I would suspect a fairly spectacular leak.
When the compressor is running does the gauge ever rise at all?
If the answer is no, then suspect:
1. A bad gauge
2. A bad compressor
3. One heck of a leak
If the compressor pressure rises and then leaks down, then
suspect:
1. A bad check valve if installed.
2. A backwards leak through the stopped compressor.
3. A leak in any of the lines between the compressor and the valve / solenoid assembly. (unless you installed those shut of thing and have them
turned off.)
4. A bad compressor.
5. Bad air pressure switch or unloader, if equipped.
It has been a while but I believe the compressor line goes to the Check valve then the tank and the tank connects to the manifold. I have no idea
where the gauge is connected to since it is not OEM.
You could disconnect the line at the tank and put a plug or better yet a pressure gauge in the hole where you disconnected the line. Then run the
compressor see if it will build up pressure and hold it. Run it up to about 120 PSI and shut and manually shut off the compressor. The normal
pressure switch will not shut it off because it is on the side that you disconnected. If builds up and holds pressure you know everything up to that
point is OK. If it is OK, put it back together and move on to things connected at the manifold. If not, find the problems from the tank to the
compressor and fix them.
> 1. A bad gauge
> 2. A bad compressor
> suspect:
> turned off.)
> that point is OK. If it is OK, put it back together and move on to things connected at the manifold. If not, find the problems from the tank to the
Thanks Ken...ill assess it with your helpful list and see were we end up.
Cheers
Rich Mondor,
Brockville, ON
77 Hughes 2600
