Ready to explode another myth about the GMC motorhomethat really worries people
clark searle
76
You got that right. The clutch would never disengage when running backwards. Sort
of fail safe in that direction, but no temperature control- always on full.
Clark Searle
> And another thing about running the water pump "backwards" --- the fan clutch
> will also turn backwards and they are designed for specific direction of
> rotation. Don't know what happens if you run the clutch backwards but it must
> not work as intended.
> Gary
> '77 Kingsley
> North Bend, Oregon Coast
> > Thanks for the info that your water pump is running the wrong direction.
> > Could be a start of destroying another major myth and that is we need the
> > cast iron water pump impeller or the engine will overheat. I PERSONALLY
> > THINK THAT IS BUNK!
> > If the pump runs backwards the radiator will run at greatly reduced
> > efficiency ie;reversed flow thru the thermostat, reverse water flow thru the
> > radiator etc. Mondello says the the best way to correct an overheating
> > condition if everything is in good shape is to cut off some of the stamped
> > impeller blades thus SLOWING down the flow of water thru the radiator core.
> > maybe he is right. Aren't you doing very close to the same thing by running
> > your water pump backwards?
> > Do you have a temp gauge showing actual temp, and if so has it changed? Time
> > to start getting info on another myth. Time to come out of lurk Arch and
> > take charge.
