Jim,
I, too, am having trouble with your math: "...back to 1949. I
was 19 years old at the time.". Seems to me that would make your birth
date in 1930, 7 years before mine. Since I'm 84, that makes you 91 -- and
here I thought you were one of those "Young Whippersnappers" (=Younger
than me, like most folks!)
> My math was a bit fuzzy there. I have 60 years experience with Olds, not
> 70.
> Salem, Oregon
> > But, the 455 was engineered at least ten years previously to when it came
> > as equipment in the Toronado. The first overhead valve V-8 in Oldsmobile,
> > the Rocket 303 cubic inch first appeared in the 1949 model year, the same
> > year that Cadillac changed from huge displacement valve in block design.
> > The overhead valve engines were 331 Cubic inches.
> > I had a 1938 Olds vith a in-line flathead 6 cylinder engine. I
> pulled
> > that 6 out, and bolted in a 303 V-8. Later, I added 3 ea. 2 barrel carbs,
> > and solid lifters with adjustable pushrods which promptly flattened the
> > lobes on the hydraulic lifter camshaft. So, I called Ed Iskendarian and
> he
> > set me up with a good 3/4 race solid lifters cam, new lifters, and
> > adjustable needle bearing rocker arms. That really woke that Oldsmobile
> up.
> > And started a long relationship with Iskendarian.
> > So, my personal relationship with Olds engines goes back to 1949. I
> > was 19 years old at the time. I went through 303's, 354's etc. Clear up
> to
> > present day. I have a 455 and a 403 in my shop right now on engine
> stands.
> > So that is 70 years of Oldsmobiles in my experience bank. They are good
> > engines stock, and can be made into great engines.
> > Personally, I prefer the 403 to the 455 due to the fact that the 403
> > is Oversquare and the 455 is Undersquare. The 403 likes to Rev up, the
> 455
> > is not so happy above 3000 RPM's
> > Jim Hupy
> > Salem, Oregon
> >> > Matt:
> >> > The space race to the moon was in the '60's, same time as the TH425
> was
> >> being developed.
> >> Bruce,
> >> The last man to walk on the moon did it in December 1972. TZE was in
> >> production.
> >> Matt
> >> Matt & Mary Colie - Chaumière -'73 Glacier 23 - Members GMCMI, GMCGL,
> >> GMCES
> >> Electronically Controlled Quiet Engine Cooling Fan with OE Rear Drum
> >> Brakes with Applied Control Arms
> >> SE Michigan - Near DTW - Twixt A2 and Detroit
> >> GMCnet mailing list
