You already have the gasket you need! Next time you start to change oil and
filter, remove the rubber-like gasket from your old filter and use it to
replace the gasket above. That was where the filter was located before GM
diverted the oil to the cooler located in the radiator.
Good luck,
byron maxwell/chaparral
Good luck,
