Found a neat solution for running LP tubing through plywood bulkheads.
The grommets I found were not thick enough for 1/2" wood and pulled out
easily.
Take a 3/8" wellnut (rubber with captured brass nut available from
marine supply or Home Depot), cut off the nut part, keaving a bit over
an inch of sleeve. Fits in a 3/4" hole from inside fridge and LP
compartment and holds the tubing nice and tight. A bit of silicone
seals holds wellnut to partition, though it holds pretty well without
it. Looks like nice and neat. Cost me $1.25 each.
I will probably use this for water lines as well.
Ron and Julie
73 Painted Desert
easily.
Ron and Julie
73 Painted Desert
