This business of adding restrictors or a smaller capacity
water pump for better cooling has never made any sense to me.
Slow flow through a radiator would mean a greater differental in
inlet vs outlet temperatures. Fast coolent flow through a radiator
would mean a smaller differental in inlet vs outlet temperatures.
It can be shown that the second case radiator with the
faster flow would dissipate more BTU's per second than the slower
flow case assuming the same inlet temperatures. The faster flow
case results in a higher over all average temperature over the
entire frontal area of the area of the radiator and hence more
heat transfer to the ambient air flow. This is a simplification
because the mathematics use Calculus and are more involved.
Simarly, faster flow rates through the engine block should
lead to a more uniform temperature thruout the structure vs the
lazy slow flow case and also yield the higher BTU transfer rates
as discussed for the radiator case.
The only time high flow rates would be undesirable is
when cavitation begins. Yet, ever since I was a teenager in the
days of flat head Fords, I have always been told the myth of of adding
restrictors for better engine cooling.
Can any of you engineers out there please justify the
restrictor/smaller pump myth so I can get it straight.
Thanks; DAC 78-Royale
