Random Question
thomas phipps
3,370
Realizing the GMC has a 12v system, what is the actual voltage spread range in terms of voltage and current draw, before failure of the HEI to provide
an adequate spark?
Just interested.
Tom
KA4CSG
According to the Motorola data sheet, the chip inside the HEI ignition will function down to 4 volts.
This is with a 300 ohm resistor between the battery and the chip power input.
The battery voltage during cold cranking can drop quite a bit, like maybe as low as 8 volts.
The maximum working voltage is 24 volts. The circuit will shut down if the voltage exceeds 30 volts.
It says in the datasheet:
"At lower Vbatt, the "on" period automatically stretches to accomodate teh slower current build-up.
At very low Vbatt and low RPM, a common condition during cold starting, the "on" period is nearly
the full cycle to permit as much coil current as possible."
455 F Block, G heads
San Jose
The primary side is not the problem. It''s a poor path for spark to ground on the secondary. This causes excessive voltage rise in the coil after the
module opens. The voltage rise is also on the coil primary leads (collapsing magnetic field induces voltage in primary and secondary windings).
Also the "12V system" is better referred to as a 14V system. The battery alone is 12.66V charged at room temp. System voltage is s solid 14.2 after
cold start and tapers to mid to high 13s as temps rise to mirror wet cell charge requirements.
If you suspect a distributor low voltage problem on either the primary or the secondary side of the HEI coil, one of the best things you can to is to
add a ground wire from the distributor frame to the engine block. I suggest NOT using a valve cover bolt on the engine. There are two threaded holes
on the back of the heads or a manifold bolt could be used.
The distributor is aluminum and it is mounted in a steel hole in the intake manifold. Also I have seen some with a round gasket sometimes installed
there. Over time you get dis-similar metal corrosion and a poor connection there that sometimes changes as the engines changes temperature.
On a Dick Paterson rebuilt distributor there is a terminal on the bottom of it specifically for this purpose. On other distributors, a simple small
stainless hose clamp could be used.
On the inside of the distributor there is a short bolt used to ground the internal wiring harness. You can just replace that bolt with one about 1/2” longer. It will stick out the bottom of the distributor and you cam them put a wire with a a round terminal on the bolt and use a lock washer and nut to secure it. You then run the other end of the wire to a screw or bolt on the aluminum frame of the motorbox.
Easier to do than an clamp and a much better ground
Frederick, CO
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
