RAMCO mirror orientation
john wright
1,064
Tom,
The flatter side goes towards the coach. Also you should have noticed
that one of the wires was shorter than the other. Longest one goes to
the passenger side (at least how mine came) and depending on how you
route it you may still have to add wire to reach the control switch
depending on where you mount the control switch. I have mine located
next to the drivers seat.
> Started the RAMCO mirror installation and after the first one was installed
> realized that there are two ways to mount the mirrors. One side of the
> mirror is fairly flat and the other is similar to an air foil. I believe
> that the flat side has the sticker on the lower mirror.
> What is the correct way to mount them???? There are no directions with the
> mirror. Will one way have more wind noise than the other?
> Want to finish them tomorrow.
> tom,
J.R. Wright
GMC GreatLakers
Michigan
