Ragusa
marlene meineken
1,859
Has anyone purchased a Ragusa Transmission Cooler Pan and or a Final Drive
Cooler Pan. What is your opinion????? Good or Bad.
Also what is the # for a gasket for the Transmission Pan.
455 Engine ----- 425 35P Transmission
Marlene Meineken
77 Palm Beach
AKA BIG JIM
Marlene--
I have both and have no complaints. I like the temp. monitor feature, the
extra quart of transmission fluid, and the drain plugs. I suppose cooling is
better but I had no "before" data.
Gary
North Bend, Oregon Coast
> Marlene Meineken
> 77 Palm Beach
> AKA BIG JIM
Got a link to Ragusa? Ph #? Tried one on from Gene's site, But was a no go.
Thanks
Ron
To:
Sent: Saturday, September 18, 1999 2:23 PM
Subject: Re: GMC: Ragusa
> Marlene--
is
> Gary
Drive
> > Marlene Meineken
> > 77 Palm Beach
> > AKA BIG JIM
Phone # for Ragusa that I have is
949-261-5898 Fax 949-475-1420
Address 1920 E. Warner Ave.,,Ste. 3D Santa Ana, Ca 92750
Hope this helps.
Marlene Meineken
To:
Sent: Saturday, September 18, 1999 2:33 PM
go.
> Thanks
> Ron
> From: Gary Miller
> To:
> > Marlene--
the
cooling
> is
> > Gary
> Drive
> > > Marlene Meineken
> > > 77 Palm Beach
> > > AKA BIG JIM
Ragussa does not have a web site (that I know of). Their phone is (949)
261-5898.
Gary
> Thanks
> Ron
> From: Gary Miller
> To:
> > Marlene--
> is
> > Gary
> Drive
> > > Marlene Meineken
> > > 77 Palm Beach
> > > AKA BIG JIM
Thanks Marlene and Gary, I couldn't get e-mail thru, Never tried the # till
today. Thanks again
Ron
Marlene: I have both on my coach and I haven't put enough miles on them to
say that they help. However, the transmission pan is generally considered
of merit. I like the look of the final drive pan and it does allow the oil
to be drained without taking it off (I think). They are also drilled and
tapped for temperature sensors. I would recommend buying the Ragusa
products from Caspro. The price is (was) similar to Ragusa and Caspro adds
in a couple of nice items. The instruction sheet that Caspro prepared is
very clear and helpful. They also recommend not using a gasket and they
include the high temp sealer in the package. When I discussed this with
Ragusa, they said that they just use a gasket. The other advantage of
buying from Caspro is that you can get excellent (if not overly friendly)
technical support.
As an aside, I should mention that I like buying from a company like Caspro
if the price is reasonable. I have found that his equipment is extremely
well engineered and the installation instructions are well thought through.
You can also call and get support (but good technical support seems to be
the norm with most of the GMC suppliers which says a lot about the nature
of the community). The problem tends to be in the pricing. His shocks,
transmission shift kits, oil pans and many other items are very
competitively priced. However, I found significantly lower pricing for rear
sway bars and steering box (which I believe to be of similar quality and
features) from other suppliers.
Vic Marks
Vancouver BC
75 transmode.
It's hard to say, but I believe the Ragusa tranny pan dropped my temp by 10 to
20 degrees (measured at transmission outlet). In addition, you get a convenient
drain fitting so you don't have to drop the pan to change the oil, as with the
OEM version. As for the gasket, when you buy a new tranny filter (which you
should install), you'll get a new gasket with it.
Clark Searle
Mt. Pleasant, MI.
> Marlene Meineken
> 77 Palm Beach
> AKA BIG JIM
Then I guess the question is what is the # for the tranny filter? And where
is the best place to go get one?
Marlene Meineken
To:
Sent: Saturday, September 18, 1999 6:53 PM
10 to
convenient
the
you
> Clark Searle
> Mt. Pleasant, MI.
Drive
> > Marlene Meineken
> > 77 Palm Beach
> > AKA BIG JIM
Marlene Dont own Ragusa Trans pan but do have Ragusa step which I'm very
happy with. There was some mention a while back that the Ragusa pan gave you
less ground clearance than stock pan. Might ask someone who owns one if this
is any concern to you
Bill
I use the pan. Bought it so I could add a temp gage and have a drain plug.
It is probably worth the $$$ (to me, anyway).
tw
Thomas P. Winslow
1974 GMC Eleganza SE TZE064V101146
189 Hicks Creek Road, Troutman, NC 28166
h704-528-5868 * f704-528-5868 * p704-878-1157
E-Mail: winslow * tom_winslow
Web Page: http://www.iredell.com
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Bill
Satterfield
Sent: Sunday, September 19, 1999 5:28 PM
To: gmcmotorhome
you
this
Bill
Hi Vic, So the Ragusa and Caspro Tranny pan are the same pan? Is the final
the same also? Do you use the sealer or gaskets for both? thanks for any
info.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
To:
Sent: Saturday, September 18, 1999 5:24 PM
Subject: GMC: Ragusa
> technical support.
Caspro
through.
rear
> Vic Marks
> Vancouver BC
> 75 transmode.
The Ragusa Site is: http://home1.gte.net/ragusarv/index.html
> Marlene Meineken
> From: Clark Searle
> To:
> 10 to
> convenient
> the
> you
> > Clark Searle
> > Mt. Pleasant, MI.
> Drive
> > > Marlene Meineken
> > > 77 Palm Beach
> > > AKA BIG JIM
