Jerry
I believe the slope of your radiator is related to the blow that it
sustained, which would tend to push the bottom rearward. My radiator and
A/C condenser are at 90 degrees to the frame, totally vertical.
Chuck
> From: Gerald Schmitt
> To: gmcmotorhome
> Subject: GMC: Radiator mount
> Date: Monday, October 05, 1998 2:28 PM
> >Howdy All,
> >I have a 1974 GMC 230 and am in the midst of restoring it. During a
recent
> >outing we hit a bump and grounded the bottom of the radiator mount.
After
> >this incident the fan was hitting the fibreglass part of the fan shroud.
> >To my eye the radiator mount and all is sloped with the bottom more
toward
> >the rear of the coach than the top. The lower part of the fan shroud is
also
> >where is was hitting. I tried loosening the radiator housing mounting
bolts
> >and straightened it somewhat but it still hit. My stopgap fix was to
remove
> >the fan but I want to make it right before next summer.
> >Is the radiator supposed to be straight up and down? If so is there a
> >standard
> >place where the mount bends?
> >Thank you for any help you can give me.
> > Jerry
Chuck
> To: gmcmotorhome
> >Howdy All,
recent
After
toward
also
bolts
remove
> >standard
> > Jerry
