Questions:Intake manifold replacement no intake gasket
jack ramsey
58
NO intake gasket except the turkey tray, large amount of gunk in the water jackets, orange silicone in the oil galley, RUSTED intake bolts.
I am thinking clean up the turkey tray, possibly not replace it, clean everything up as much as I can, install fixed stock intake with Jim K gaskets
and block of plates, intake from Jim K also, fill the exhaust crossover with Moroso engine block filler, just in case, install the Jim K supplied
Atomic FI and run it for a couple of weeks. THEN pull the radiator and send it out, while replacing the 20 yr old water pump and checking the timing
chain sprocket at the same time. No sense in putting in a new water pump with the amount of gunk from 20 yrs of sitting swirling up and stirring up
the mess.
I see from YouTube, some people think the front and rear intake to block gaskets should not be used. Any thoughts? Am I thinking OK? I have never see
this amount of gunk in a cooling system. Since I am an old air cooled mechanic, I think it is important to think about thermal expansion of the bolts.
I am probably overthinking simple stuff. get new intake grade something? bolts, torque them down and move on. Have to improvise a little on the
threaded pieces holding down the myriad of assorted brackets for cooling shroud and rest of system.
Turkey tray overall mess:
http://www.gmcmhphotos.com/photos/atomic-tbi-fuel-injection/p66439-turkey-tray.html
Water Jacket Gunk:
http://www.gmcmhphotos.com/photos/atomic-tbi-fuel-injection/p66440-water-jacket-gunk.html
Edelbrock no gasket:
http://www.gmcmhphotos.com/photos/atomic-tbi-fuel-injection/p66442-edelbrock-no-gasket.html
Thanks,
Jack
Jack Ramsey
Tulare, CA
TZE165V101526
1975 Palm Beach
In my opinion, ditch the turkey tray and use Dick Paterson’s intake gaskets
with stainless steel exhaust crossover block-off plates, following his
sealing instructions.
Remove and meticulously vacuum out the silicone bits. Don’t leave any
silicone bits anywhere.
The turkey tray is there to keep oil from splashing up and coking in the
hot exhaust crossover passage of the manifold. With block-off plates, it
won’t be that hot.
The crossover is for carb heating, which we simply don’t need.
You’ll need to install an electric choke.
If the bolts just have surface rust, i would probably wire-brush and reuse
the. If the corrosion has eroded them, replace.
Use a wide RTV bead to seal the end gaps, instead of the gasket-kit rubber
things. Be sure that gasket surfaces are carefully degreased before
applying sealant.
Check port alignment to make sure you have good and wide gasket compression
around the water jackets.
Tighten the bolts to half torque, and let the sealant cure overnight, if
possible. Then tighten to full torque, noting the order in the maintenance
manual.
I bet you’ll need a new thermostat. Make sure the thermostat neck seats and
tightens properly. I’ve had issue with this.
Rick “and fresh fluids, of course” Denney
On Mon, May 27, 2019 at 9:42 PM Jack Ramsey via Gmclist <
> gaskets
> timing
> the mess.
> bolts.
> Water Jacket Gunk:
> Thanks,
> Jack
> Jack Ramsey
> Tulare, CA
> TZE165V101526
> 1975 Palm Beach
'73 X-Glacier 230 "Jaws"
Northern Virginia
Call as we have All the parts including the special choke wire connector
and will advise you on the hook up and adjustment .
On Tue, May 28, 2019 at 7:15 AM Richard Denney via Gmclist <
> won’t be that hot.
> applying sealant.
> manual.
> water
> > gaskets
> > timing
> up
> > the mess.
> see
> > bolts.
> > Water Jacket Gunk:
> > Thanks,
> > Jack
> > Jack Ramsey
> > Tulare, CA
> > TZE165V101526
> > 1975 Palm Beach
> Northern Virginia
You can use a centre punch and put some dimples in the block where you are putting the silicone bead
when installing the intake. They help hold the silicone in place.
When putting the silicone on, let it sit for a few minutes before installing the intake.
