Whats the process for getting up on these ramps?
Just pump the coach up as high as it will go......slide them in from the sides under the coach then drive forward up onto them?
I assume the limited height to slip them in is the limiting factor in how high they can be.....
Can one still put a block under between the rear wheels to stop the coach dropping as much in the event of a bag bursting.
got some things I need to do to things under there and its time i bit the bullet and made a set.
Pete
Cary, NC
1978 Center Kitchen Royale.
Pete
Cary, NC
