Quality of rear brakes and E-brake
chuck will
479
> Dave,
> Not too sure about the vent fan problem (just know I'd rather hack up the
> fan to fit the coach than vice-versa).
> Regarding the parking brake: First make sure all 4 rear brakes are in good
> condition AND PROPERLY ADJUSTED (most aren't). Be sure the brake cables are
> slack when adjusting the shoes. Then (and only then) adjust the cables, first
> backing off the "adjustment" knob on the hand brake lever. To apply, step on
> and hold the service brakes while applying the E-brake.
> If you still have trouble, replace the cables, lubing up the new ones
> thoroughly. Then remember to USE the parking brake every time you park,
> EXCEPT for long-term storage. (Admittedly the GMC E-brake is a little
> anemic.)
> Good luck.
> Rick Staples
Hi : About the parking brake and making sure all rear wheels brakes
are in good shape. The GMC is supposed to adjust these brakes when
backing up if the "Star" is in good shape. I replaced all 4 of these
"STARS" when checking the brakes and had to change one drum that was
ruined due to improper adjustment. Question: Is there anything else to
check to ensure these brakes are in good shape as mentioned Rick?
Thanks Chuck
