Ken, with when
Under normal conditions using spliced the wire that feed the HEI is very
good.
However lot if the wire has been spliced with smaller wire and we have run
into poor distributor and choke issues. Again when one confronts all type
mods it is trusting.
On Sun, Mar 29, 2020 at 7:52 PM Larry via Gmclist
wrote:
> > Ed,
> > Side note....
> > If you replace the points with A Pertronix 1181LS, that is a very
> reliable mod. (You can put the removed points and condenser in a jar and
> carry
> > then as spares if you are paranoid.)
> > Matt
> For those considering a Pertonix conversion, this is a copy/paste of a
> post I did a while back. I repost it here because it is worth noting.
> The points type distributor I have for my 73 Cad 500 needed rebuilding. So
> I sent it to Dick Paterson. He replaced the points system with the
> pertronix 1181 and recurve the distributor. That was in 2005. Last summer,
> while doing some work on the FI that I have, it suddenly refused to start.
> After some diagnosis, finally found it had no spark. The 1181 has a
> pick-up and a ring of magnets that go under the rotor. One magnet dislodged
> and in
> turn scrubbed the electronic eye until I had a total ignition
> failure--complete with coil boiled out. Called and talked with Dick and he
> said that
> they had problems with the 1181 Magnet ring, that I should order the
> 1181ls (LS is for Lobe Sensing), which does not have Magnet ring. I ordered
> the
> "Flamethrower" 40011 as the matching coil. Got them from Summit. They had
> the lowest price and quickest shipping. (next day) Works fine...no moving
> parts accept the lobes. With the 1181ls you take the points and condenser
> out, and drop the 1181ls pick-up in it's place. Takes about 5 minutes. Very
> easy install. Most GM points type distributors use common parts, so the
> 1181ls should work in your Olds distributor. JWID
> Larry
> 78 Royale w/500 Caddy
> Menomonie, WI.
http://www.gmcrvparts.com
