> By " air door" in the secondary barrels do you mean the twin large
> spring loaded air valves at the top of the carbruretor? I'll follow
> your advice and see if I can locate the allen head set screw on the
> spring tensioner and check to see that the adjustment is right.
Yes, the secondary air valves look like a "choke" over the secondaries.
I thought Roe covered this adjustment in his book, but if you look on
page 166(hoping that your edition is the same as mine), you can see what
looks like a screw behind the secondary block link. That's the
adjustment screw. The set screw is underneath the boss that the
adjustment screw is in. You can't see it, you must feel for it.
Another thing to check is that secondary block link. On the Q-jet, the
secondaries are blocked from opening until the choke pulls off. If that
block link does not move freely, that would also result in
overenrichment and loss of power.
Hope this helps!
Patrick
Patrick Flowers
Mailto
atri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Hope this helps!
Patrick
Patrick Flowers
Mailto
