I'm collecting egt data in the hope of being able to graph it at some point and take note of changes with time.
However, now I'm not sure it'll work.
I'm collecting, every 10 seconds at the moment, all 8 egt's and also a spread between coldest and hottest.
My thought/hope was that if I maintain the same spread for same rpm, manifold press, etc it would be an indication of engine health as it would be unlikely that all plugs fouled same, etc. so if a ring was failing or some other horrible thing, the egt should show it and it should show up in the spread. Or if a plug lead falls off if should be noticable as well. ( don't laugh, it's happened
What I'm getting though is variations when I didn't expect any. I.e. it'll be a 200 degree spread and all of a sudden jump to 400 and then back to 200 (not accurate, figures are only for illustration purposes but they do vary that much). The high one is only momentary, perhaps only 1 or 2 hits but the do exist.
Is it possible that firing instances are such, occasionally, that one is just firing and another sucking cold?
I havn't checked the actual temps at that time yet... still working on my database/graphing scheme.
perhaps 10 seconds is too coarse? I'm going to go for constant on the next leg of my trip, but was just wondering if I'm totally off-base in my hope and quest of decreasing the chance of unexpected failure in this manner.
Thanks in advance for thought and comments.
Heinz
...with too much information
Heinz
