Tony,
I one comment to add to those from Tom and Mike: If you intend to replace
the cockpit curtain with one from Margaret Guskey (the accordion-fold type
that seem to be most common in current GMCs), you should go ahead and order
it. The reason being that you'll be removing the OEM aluminum track to get
the headliner out; you might as well replace it with the Guske track and
avoid another R&R exercise.
You may also want to consider adding some wooden blocks near the center of
the span, especially if you have distant dreams of adding an overhead
console, shelf, etc. With the headliner down, it's easy to cut away a
little foam and mount blocks with glue (Liquid Nails) and screws laterally
through the molded-in roof struts. You'll have to guess, based on "your
dreams" where those should be positioned.
While the headline is down is the right time to replace the clearance
lights, or at least examine/modify their wiring. The foam insulation was
sprayed over the wires; it's not unusual to remove a clearance light from
outside and have one of the bullet connectors "automatically" separate
because there's little slack in the wires. There's also the matter of wire
polarity: MANY of the wires that should have positive polarity actually
have negative -- and vice-versa for the negative. That's not a problem
since the roof is not conductive and the incandescent bulbs are not
polarity sensitive. But if you replace those with LED's, the polarity MUST
be correct -- now's a good time to check and mark the wires.
Don't forget to add some insulation to the meager OEM application; it will
help keep the cockpit cool/warm.
> Ant advice on removing the plastic cockpit headliner/surround? I need to
> remove it such the it can be re-installed.
> This is on my '78 Eleganza II. Is it glued anywhere? My seats are out
> getting the leather cleaned up and re-cushioned, so I have good access.
> Hoping to hear from those who have actually done it rather than
> theoretical assumptions and reasons to not attempt it.
> --Tony Bennett
> Watkinsville, GA
> '78 Eleganza II 26'
> '73 Toy Hauler 23'
