Pulling the heads on this 455
dave2
11
I'm going to pull the heads off this 455 here soon and do some much needed top end maintenance. The motor was built years ago by some shop down in
Texas and runs good, but there are a few problems which have developed over the years, which the previous owner passed on to me: leaky valve covers,
leaky valve stem seals, and carbon buildup in the combustion chambers leading to dieseling on hot shutoff. Probably plenty of carbon to be found in
the valley area also, I'm guessing. All that plus the leaky header gasket on one side.
So I'm just going to pull the heads off, refurbish them, and solve all these problems in one go. Maybe do some port work too while I'm in there,
because why not? At 10k feet in the mountains she could use a little extra grunt.
I'm just wondering if there any known snags or potential trouble areas in the head pulling process on these coaches that I should know about before
getting started. Thanks for any advice.
Sir, since the Olds valve adjustment is preset you will need to have the head gaskets so the machine shop can set up valve lash properly. Try to get
all the antifreeze out of the engine before removing heads. If coolant does get in cylinders vacuum or wipe it out ASAP. It will rust cylinder walls
and rings and will be harmful to rod and main bearings. It will be a good time to check timing chain and gears and expansion (freeze) plugs.
> before getting started. Thanks for any advice.
C. Boyd
76 Crestmont
East Tennessee
Dave,
This is not an unreasonable thing to do, but I didn't do it which is why I will make some suggestions:
Plan to use the Dick Paterson cross over block off kit. This means you also now need an electric choke.
If you have stock manifolds, the Dave Lenzi copper gaskets work great but they do need several retorquings.
--If the mating surface is not flat, find a big belt sander to fix that.
Look for the block side coolant drains (2) so you don't have to deal with coolant in the cylinders.
Plan to remove the wheel well liners and front tires to get enough room to swing the big guns to get the exhaust manifolds off.
Plan to rig lifting gear to both lift and lower the heads - They are heavy. You do not want to drop them onto the new gaskets.
You can hang the A/C pump under the floor and not break the system - if you care.
Doing the water pump and timing chain will be way easier if you remover the radiator.
--It is not that big a job and the condenser can be rotated out to the right if you did open the system.
The bolts and springs for the exhaust flanges are easy to get, so cut them if they are tough.
It sounds like you already have the intake off, so you might have completely removed the steel fuel line to the carburetor.
--If not, you will want to do that.
That is all I can think of right now, but I am sure others will add to this.
I took my whole engine out the front because it needed more than just a valve job.
If you or your shop are going to replace valve seats, make damn sure you or they know what you're doing. Trying to put Chev big block seats in will
destroy the heads beyond further use. If the shop chief says "Hey, and Olds 455 head - haven't seen one of those in a while" you found the correct
shop to build them. OTOH if s/he says 'Off a 454 huh?' take your custom elsewhere.
--johnny
Braselton, Ga.
I haven't taken it apart yet, just collecting parts and getting ready for it. Maybe the heads will just need a good cleaning and seal replacement, but
if any seat or guide work is needed, I do know a good place to handle that.
This coach has headers, and I don't think they are too rusted on there, so maybe that part will go smoothly.
How do you time the ignition on these motorhomes? That's something I wondered about. Seems like the timing marks would be hard to see, but it's been a
while since I looked.
Thanks for the tips everyone.
It's possible to see the marks but it ain't easy. While you have the heads off, set the #1 to TDC. Use a dial gauge to be sure it's at the exact.
Check the mark to make sure the dampener hasn't slipped (If it has, replace it,it wil slip again). Now make another TDC mark with a scribe where you
can see it, and make a pointer for it. Then back the engine up till the 8degree mark on the dampener lines up. Scribe your new place again. Mow
you're set, you can static time it without being a contortionist and you can use a timing light when you get it running.
--johnny
Braselton, Ga.
Sir, it is much easier to see 0 (tdc) than it is to see 8-14*. Try to find a timing light that has a dial on it to preset timing degrees. If you
want 12* set the timing light on 12* then set timing on the engine at 0 (tdc).
> exact. Check the mark to make sure the dampener hasn't slipped (If it has, replace it,it wil slip again). Now make another TDC mark with a scribe
> where you can see it, and make a pointer for it. Then back the engine up till the 8degree mark on the dampener lines up. Scribe your new place
> again. Mow you're set, you can static time it without being a contortionist and you can use a timing light when you get it running.
> --johnny
C. Boyd
76 Crestmont
East Tennessee
I'm too dam' cheap to buy a settable light :)
--johnny
Braselton, Ga.
> --johnny
Johnny,
They are some that are cheap at Hazard Fright, but some have been reported to not work right.
So, your only choice is to plop yourself on the belly board and keep fiddling with things until you are tired.
Did you ever wonder why Olds chose to use just a machined slot in the
compensating balancer instead of a row of marks on it? It is because the
"HIGH ZOOT" Kent Moore Shop diagnostic scope had a magnetic pickup instead
of a timing light. All that stuff appeared magically upon the screen, after
you had correctly attached the various leads from the scope. On the 403 and
other engines later than the 455, there is a provision on the timing
pointer for the magnetic pickup on the scope to keep it out of harms way
with the engine running. Remember, that engine was grabbed off of the
automobile production line.
Salem, Oregon
On Sat, Jan 2, 2021, 8:51 AM Matt Colie via Gmclist
> > --johnny
> Johnny,
> to not work right.
> Matt
> GMCES
> Did you ever wonder why Olds chose to use just a machined slot in the compensating balancer instead of a row of marks on it? It is because the
> "HIGH ZOOT" Kent Moore Shop diagnostic scope had a magnetic pickup instead of a timing light. All that stuff appeared magically upon the screen,
> after you had correctly attached the various leads from the scope. On the 403 and other engines later than the 455, there is a provision on the
> timing pointer for the magnetic pickup on the scope to keep it out of harms way with the engine running. Remember, that engine was grabbed off of
> the automobile production line.
> Jim Hupy
> Salem, Oregon
Jim,
Nice thought, but that Kent-Moore system can only go with the plastic "timing saw" scale that came along with the HEI ignition. Those were the first
with the place to plug in the magnetic pick-up. I have seen it on some of the 455s too.
Heck, I didn't say that it was right, or exact, or anything like it. I have
been factory trained (brainwashed) at GM Training Centers, as well as
attended seminars from Mitchell's and Motor's manuals.
So, I have a foot in both worlds. GM was not too generous with what
they considered "proprietary information" and didn't want to share it with
Independent Shop owners. Not until they lost a class action lawsuit,
anyway. Just the way it was/is.
Salem, Oregon
On Sat, Jan 2, 2021, 10:38 AM Matt Colie via Gmclist <
> screen,
> > Jim Hupy
> > Salem, Oregon
> Jim,
> first
> the 455s too.
> Matt
> GMCES
Well I got the heads pulled off today. The engine was very clean inside, no gunk or carbon built up anywhere; looks like a new one in there. The only
surprise was a bent pushrod!
Not sure how this happened; maybe a sticking valve? The one pushrod is pretty warped, but everything else looks great.
The motor ran fine, although it was somewhat cold natured, which I thought was due to the cam; it wouldn't idle well until warmed up. Come to think of
it, it was a bit lumpy when turning over, like compression was down on one cylinder.
Anyone know if a bent pushrod/sticking valve can cause dieseling? There definitely wasn't enough carbon in the chambers to cause a problem.
Anyone got a couple extra pushrods laying around? :roll:
> only surprise was a bent pushrod!
> think of it, it was a bit lumpy when turning over, like compression was down on one cylinder.
Dave,
First is, yes, I have a few because I ended up with a nearly complete 455 that is scrap. Actually, I have to look and make sure that they are in
there.
Problem: Your sigfile (hint) gives no location. At lease you called out 455, so we can get that right.
Second...
Push rods live their entire existence with a gnat's wing span of failing. They flex enough that this extra motion has to be accounted for in the cam
profile.
Lastly, a question for you.
Was it an Exhaust or and Intake, and on which cylinder??
While I would suggest replacing the valve guide seals (unbrellas), my engine was 75K off a cheap rebuild and it didn't need any head work, but I had
it done anyway. Now it is in my book and the SO will get a complete picture of what was done.
In your case, it is very likely that the valve stuck in the guide, rather
than something in the cylinder obstructing the opening of the valve. So,
the head needs to come apart, and the valve to guide clearance carefully
checked. Obviously lube issues need to be checked for, bent valves, etc.
Something caused the problem. Needs to be found and corrected.
Salem, Oregon
On Sat, Jan 2, 2021, 3:45 PM Matt Colie via Gmclist
> Dave,
> there.
> Second...
> profile.
> had
> Matt
> Matt
> GMCES
I'm near Gadsden AL.
Unfortunately, I didn't think to check if it was an exhaust or intake pushrod, until after it was already removed and mixed with the others. It was on
cylinder #3 or #5.
Given that everything else was fine, and has been for many miles, I assume there isn't a problem with pushrod length, and this was most likely caused
by a sticking valve. Maybe due to starting on old gas.
Did some searching about dieseling, and looks like this could very well be the source of the problem, particularly if the throttle were adjusted open
extra to help the idle.
One time my dad started a truck on old gas which quickly turned to varnish, seized valves, and bent several pushrods. I learned the lesson and always
pour fresh gas in a vehicle before starting if it's sat for a while. I guess this must have happened under a previous owner and the pushrod has been
bent like this for no telling how many miles.
I will get the heads disassembled tomorrow and see if there are any problems with the guides or valves. Going also tomorrow to see if I can round up a
new air compressor on the cheap since my old one died. Hope so cause I want to get some port work done on these "J" heads and intake, while
everything's apart. :d
By chance was the engined started and raved high that may have caused a valve or two to float, bending the push rods?
Randy Hecht
Roswell, GA
1974 Canyon Lakes GMC Motor-coach
