Much to my amazement I received a call yesterday. The coach is running and
the owner is going to meet me part way. Wow! What a change in attitude from
a week ago! The coach was completely dead, no batteries, the engine head
were off and it had very droopy but.
I guess the owner just took pity on a new GMC Owner.
Thanks for all of your suggestion! I will have more questions I know. Will
let you know when the coach is home.
Thanks
Jack Todd
- -----Original Message-----
[mailto
wner-gmcmotorhome] On Behalf Of Thomas G. Warner
Sent: Thursday, April 08, 1999 5:03 PM
To: gmcmotorhome
Subject: Re: GMC: pulling a GMC Motorhome
Emery you are of course right. I only commented on how easy it is to remove
the axle shafts. One could than install the outer CV race(an old one), and
nut to hold in the bearings and brake rotors. Even though it could be done I
sure would not tow it.
Back to the original question, can't the engine be started?
>the axle bolts at the wheel and than removing the complete shaft. It is
not
>necessary To remove the ball joints etc. To do so. You should be able To do
>it in 45 minutes for both sides. >>
>Tom - see Rick Staples message. Damage will result To the wheel bearings
and
>hubs if the stub axle isn't tightened into the bearings. So the only way
>this could be done would be To disconnect the inner shaft at the CV joint.
>Quite a job. I wouldn't recommend it over the other alternatives of towing
>or hauling the GMC on a flatbed truck or trailer.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
