I use a similar routine, starting with an empty holding tank.
* Turn on fresh water pump.
* Lay shower hose on bathroom floor.
* Open bathroom hot water; run until air bubbling quits then turn off hot.
* Do same for cold bath faucet.
* Repeat for kitchen faucet.
* Turn off fresh water pump.
* Hook external air compressor to city water inlet with adaptor.
* Repeat previous steps using air to clear lines fully.
* Activate shower diverter and clear shower hose for both hot and cold.
* Turn off each water valve when no water comes through.
* Flush toilet.
* With air still running, disconnect water feed to toilet to drain that line into shower drain.
* Turn off external air compressor.
* Fill P-traps of bathroom, kitchen, and shower drain with pink stuff.
* With holding tank drain open, you know you have enough pink in each drain when a little bit of pink drains out the pipe. Put the cover back on the drain pipe.
I used just about a gallon of pink. At this point, I figure any residual water has plenty of room to expand without damaging anything.
Have a beer or such and wait for Spring.
~~ ~ D C "Mac" Macdonald ~ ~~
~ ~ Amateur Radio - K2GKK ~ ~
~ ~ USAF and FAA, Retired ~ ~
~ ~ ~ Oklahoma City, OK ~ ~ ~
~~ ~ ~ "The Money Pit" ~ ~ ~~
~ ~ ~ ~ TZE166V101966 ~ ~ ~ ~
~ ~ ~ '76 ex-Palm Beach ~ ~ ~
~~ k2gkk + hotmail dot com ~~
www.gmcmhphotos.com/okclb ~
______________
*--OO--[]---O-*
> To: gmclist
> From: mygmc
> Date: Thu, 28 Nov 2013 12:31:22 -0600
> Subject: Re: [GMCnet] Propylene Glycol RV antifreeze
> My approach is to follow the instructions in the GMC manual that describe a winterizing process that does not involve putting RV antifreeze in the system.
> --Jim Miller
> 1977 Eleganza II
> 1977 Royale
> Hamilton, OH
> The manuals must be different from year to year. My ?Motorhome 1976 Operating Manual Model ZEO6581? states that for ?Winter Storage-Below 32F. (0C)" to use antifreeze.
> Page 102, section 3, paragraph i: ?......Add antifreeze solution (5 gallons non-toxic, non-flammable antifreeze and 5 gallons water) to living area water tank. Open all faucets and turn on water pump. When colored water comes out of the faucets, close faucets?....?
> For the past 15 years my procedure is to drain the freshwater tank, blow out the lines via the city water inlet with compressed air (at around 30 PSI) including both water heaters (OEM electric and my new LP tankless heater). Then isolate both heaters with water heater bypass valves. Then I use a winterizing kit to pump the pink stuff through the system. Pour pink stuff into the traps and a gallon in the previously drained and cleaned black water tank. I run the macerator for a few seconds until I see pink in the discharge hose.
> I never add antifreeze to the fresh water tank because it is a real bear to get rid of it in the spring. I rely on just draining it to winterize. I've also found that it is a hassle if you get antifreeze in the electric water heater. It seems to take a lot of flushing to get it out.
> This all takes less than 30 minutes and 2.5 gallons of the -50 degree antifreeze (I don't add water). I used to use about a gallon of antifreeze when I didn't have the tankless water heater, water filter and macerator. So far, no problems in the 16 times I've done it that way.
> Richard
> 76 Palm Beach
> SE Michigan
www.PalmBeachGMC.com
