FWIW, I try to fill the coach up with E-Zero and Stabil when it's going to sit for an extended period.... (Our big, flat tanks have a lot of surface
area for condensation to form) But on the road I fill with whatever "Top Tier Gas" gas station is convenient.
Jim Hupy: I am unfortunately too young to have experienced the 50s or bought 105 octane leaded fuel outside a racetrack (at like $10 a gallon)... But
don't poo poo the ethanol too much, as it also just happens to be around 105 octane if you have an E85 pump in your vicinity.
I bet even in the 50s, you couldn't get 105 octane fuel for 20 cents less per gallon than the cost of good old regular gas.... Even with the fact
that you need to burn more of it, it's still a screamin' deal if you are looking for cheap, high octane fuel...
And in a boosted engine, the ethanol will pull a good deal of heat out of your intake air temps as it vaporizes... (Like a chemical intercooler) With
the intake air temp drops, the E85 performs like it has even higher than 105 octane....
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
Howell Injection,
Fort Worth, TX
