Here is the information I got from loctite on the proper application for the
GMC ball joints. Any comments/
>Mr. Warner,
>Using a Loctite product on the flange areas of the ball joint will give
>added security. There are probably better products than the 271 for this
>flange application. We have flange sealants, or gasket eliminators, as they
>are called. The two most common are 515 and 518. For any flange assembly,
>gap plays a role. The 515 and 518 are good up to .010". If you have a
>larger gap, the Loctite 504 will go up to .030". These materials can
>typically be disassembled by either prying up one side of the flange, or by
>applying a side impact load after the bolts have been removed.
>If you have any other questions, please call our Technical Information
>department at (800) 562-8483.
>Regards,
>Cathy
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>Mr. Warner,
>Regards,
>Cathy
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
