If your giving off smoke, check to see if there is a adjustable sleeve to
allow more air to mix.
On Sat, May 4, 2019 at 4:31 PM John Wright via Gmclist <
> Dean,
> Propane does not go bad. The regulator, hoses and final end user can
> deteriorate, and at least the rubber parts can age out. Would suggest that
> you could have a low pressure coming out of the regulator, check it , it
> should be 11 Inches/water. What end user are you talking about, stove or
> heater. Check the air passages to the burner and furnace for mice deposits
> or spider webs.
> J.R. Wright
> GMC Great Laker MHC
> GMCGL Tech Editor
> GMC Eastern States Charter Member
> GMCMI
> 78 GMC Buskirk 30’ Stretch
> 75 GMC Avion (Under Reconstruction)
> Michigan
> > On May 4, 2019, at 7:20 PM, Dean Hanson via Gmclist <
> > Does propane get old? Like 10 year old - old ? Mine still burns but
> seems to
> > put out 'smoke'. Not good combustion. Just wondering.
> > Dean C. Hanson 75 Avion twin bed raising from the dead.
> > P.O.Box 2096
> > Fremont, Ca. 94536
> > (510) 657-9600
http://www.appliedgmc.com
