Propane to 4KW onan
SteveW
567
44
28
Greetings from Southern California -
Has anyone done a "dual fuel" conversion to a 4KW onan generator... In a 23 footer ??
Jerry -
Might it be significantly different than your Western States write up ??
Thanks in advance for your comments.
Steve W
1973 23'
Southern California.
As you guessed, the Western States presentation by Jerry Work will not work in the 4K Onan. There's no space to mount the fuel control module on the
4K engine. I believe I've seen a propane modification where the fuel control was mounted at the back of the battery compartment which is a
possiblity. Aside from the mounting logistics, most of the parts from WS Carb would be needed to convert the 4K.
Jack Christensen - K6ROW,
'76 Glenbrook/Clasco - "The Silver Bullet",
Sebastopol, CA
Thank you Captain Jack !!
I'll poke around for a location... My onan battery compartment is already stuffed with two 12V Optima (house) batteries.
I figure that the carb "insert" will be the same.
How far away (from the carb) can the fuel control module be ?? I suspect that this distance is not a critical factor...
Thanks again,
Steve W
1973 23'
Southern California
Rd not quite true
See here and more to follow soon
https://www.facebook.com/groups/classicgmcmotorhomes/
> the
> Sebastopol, CA
Alternator Protection Cable
> Rd not quite true
https://www.facebook.com/media/set/?set=o.183025891821956&type=1
> On Sat, Aug 26, 2017 at 8:22 PM Jack Christensen
>> the
>> Sebastopol, CA
>> GMCnet mailing list
Gnen,
Congratulations I didn't think it could be done! It looks like the generator compartment was also modified. Was that a requirement? Also, the
control module isn't that close to the carb where the injector is located which was a concern.
Sebastopol, CA
