As Carl says the LP valve does have a tendency to leak slightly when turning it on or off. It should be only in the fully open position or the fully closed position. The stops at either end act as seals for the shaft. If it leaks at either stop then you should have it replaced by an approved LP service/filling station.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> I think it is pretty common for those to leak during the process of turning them on and off. They don't seem to leak when all the way on, or all the
> way off. I guess if yours does, you should replace it or have a propane dealer replace it for you.
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final drive, Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear American Eagles,
> Solar battery charging. GMCSJ and GMCMI member
