A PO removed the OEM tank and installed a gas grill tank fitting on the regulator. I have the OEM tank and need to re-install it in the Sequoia.
I don't have any of the mounting hardware.
Is there supposed to be anything under/on top of the plywood to span body framing members, or fender washers on the bottom or what?
Carriage bolts?
I can't tell anything from the CanyonLands, as a PO removed the OEM propane tank from it as well. I can cannibalize the regulator and any other gas
plumbing stuff I need from it, but there are only 4 holes in the bottom of the compartment to hint at what was originally there.
If there is some kind of bracket/hardware above or below the plywood, pictures would be greatly appreciated.
73 23' Sequoia 4 Sale
Upper Alabama
Carriage bolts?
Upper Alabama
