Problem with holding tank
chuck will
479
If for some reason somebody did not dump as they should have or had
water in the tank as they should have then the C_ _ _ will stick to the
bottom of the tank and cause much problems. To break this loose you
should soak it with pine sol. Just a little. Some hot water. And Yes
you can get your arm in that hole and scrape it with a wide blade putty
knife. Recommend you drop the tank and at least check all the parts
that rust. Probably need a new gate valve. And if I would have only
know I would have sealed up the hole for the gauge. When you run out of
water you need to dump. I dump all the time or when ever I see a place
to do so. I do not usually carry all the water it will hold. at 8
pounds be gallon it just seems like a lot of extra weight. I wish I
could be there to help you. Chuck
Chuck,
Your efforts to help, and those of many others, give me the feeling that I
have many personal friends all across the country. I only wish that I could
repay you all some way. I am sure that I will have many other problems to
"bug" you with in the future. Thanks again.
Neely B. Tenn
- -----Original Message-----
To: gmcmotorhome
Date: Friday, February 12, 1999 7:59 PM
Subject: GMC: Problem with holding tank
