Primary venturis fuel drip at idle... and now HEI distributor issue?
dave stragand1
319
Today's findings...
Fred, you were spot on with the worn bore at the throttle shaft.
There's a noticeable bit of play. The single return spring is also way
too weak to serve any purpose, and the throttle cable stud is some
homemade deal involving a fuel line fitting and a bolt, so a whole lot
of wrong going on. I'll button it up as best as possible for the time
being, but it would need the bores sleeved at the least, if not rebuilt
or replaced with EFI.
But I don't think that's the only issue. I pulled the cap and rotor and
changed those, and tried a test on the advance/rotor arm assembly. I am
able to twist it from side to side as if under advance, but it takes a
good amount of force. Also, when released the shaft only returns half
way. I put a little movie of it up at
http://forwardlook.net/images/gmc/img_3913.mov I am guessing I will
need to pull it, strip out the shaft and give it a good cleaning, if not
a total R&R. Has anyone had the shaft 'stick' like that on an HEI
before?
-Dave
1978 Transmode near Pittsburgh
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Dave
Stragand
Sent: Wednesday, June 20, 2018 10:31 AM
Subject: Re: [GMCnet] Primary venturis fuel drip at idle
Thanks to all for the responses. I'll be stopping by today at lunch to
do some checks.
Fred -- I will check the throttle shaft bore by spraying carb cleaner on
the outside base at the shafts while it's running. Thanks for the
reminder as I have run into that before.
I'm leaning towards Bill's suggestion of a timing issue being the cause.
I recall that the rotor shaft was pretty sticky when twisting the rotor,
so I don't fully trust that all is well there. I have a new cap and
rotor so will check the shaft, vacuum advance and advance weights while
I'm in there.
Sammy -- I have had great luck with the Edelbrock (and Carter AFB's)
over the years, but if I was going to change, I would probably lean
towards Gerald's suggestion of EFI. The difference in price would be
well worth it. This is the first time I dragged out a timing light
instead of a laptop to tune a car in many years. It's nice to just turn
the key and go.
While very tempting to pour out upgrade money from the start, I am
holding off on the upgrades until we are sure she has enough 'good
bones' to continue moving forward. At present, the most I have driven
is about 20' backwards and forward -- but when she passes my wife's
"try driving it for 2 hours around the storage facility to make sure
it's in okay shape" test, my wallet will open a bit.
I will keep everyone posted with our progress!
-Dave
Yes, the hei, and to some extent, most distributors, collect iron powder
from wear of weights, springs, pins, etc. The strong magnetic fields of
rotating parts attracts this powder and gums up the mechanical advance and
rotor pieces. Combine this with long intervals between maintenance, and
eventually problems arise. Blame it on the specific ignition if you want
to, but it boils down to lack of maintenance. Spray some contact cleaner,
or brake kleen in there once in a while, follow it with compressed air, and
when it is free, lube with a non conductive lube like silicone grease or
engine oil. If you take the module out and clean that sticky stuff under it
out, be sure to replace it with heat sink grease made for that purpose.
Check the cap inside for carbon tracking, wipe it out with a clean, dry,
lint free cloth. You should be good for a long time, but nothing runs
forever without maintenance.
On Wed, Jun 20, 2018, 11:31 AM Dave Stragand
wrote:
> Today's findings...
> before?
> -Dave
> Stragand
> To: gmclist
> do some checks.
> I'm in there.
> the key and go.
> -Dave
Dave,
The distributor rotor, when turned against the advance springs should move
freely, and snap back when released. Otherwise, the distributor needs to
come out, be disassembled, de-rusted, lubricated, possibly have bushings
replaced, and be "curved" (have the proper springs and weights installed to
achieve the correct timing advance curve).
The best way to achieve all that is to send your distributor to Dick
Patterson for a complete rebuild. However, you may get by with just the
"clean & lubricate" if you do it carefully and things are gone too far.
Or, just go ahead and install EFI and an ECU-controlled distributor (which
has no weights since the ECU controls timing).
On Wed, Jun 20, 2018 at 2:31 PM Dave Stragand
wrote:
> Today's findings...
> before?
> -Dave
> Stragand
> To: gmclist
> do some checks.
> I'm in there.
> the key and go.
> -Dave
glad to be helpful.. I spent countless hours chasing a fuel dribble out of the accelerator pump venturi on an extremely rare weber. I overlooked the
throttle shaft bore wear on that one because it was very minimal. it doesnt take much, on that weber anyway.
I wouldnt rule out this set up : http://gmc.mybirdfeeder.net/GMCforum/index.php?t=msg&th=40964&start=0&rid=5513 as a replacement. you could be the
first! (if its doable lol) this would also eliminate the mechanical advance and vacuum parts of the distributor.
Just to follow up for anyone who was following this thread now or for
later in the archives...
Before pulling the distributor, I tried slipping the red tube of a WD40
can in under the advance to put a drop or two of lubricant in above the
reluctor. Worked it back and forth for a minute or so, and it started
snapping back freely.
Started up again, and the idle is much nicer, revving up is much faster,
and now the carb has only a trace of a drip from the venturis at idle.
Both the carb (worn throttle shaft) and distributor (worn advance weight
posts and too much up-down play) should be rebuilt as part of the
restoration, but they should suffice for the meantime for the coming
endurance test.
-Dave
