powermaster still there? Also Weight and San Diego puller
Feb 14, 1998
43
Dear Group GMC: Powermaster info may still be there. Try
http//ni.umd.edu/gntype/tech. Note, anytime you get a 404 or file not found
trim the address from right by one section the push your enter key, no
luck trim again and so on. If you do get in you may have to look around for
directory or something to click on that will take you to the info you
wanted. Clear as mud ? I hope so if not just ask and i'll try to explain.
Also on that weight distribution thread, some coaches came without
generators did GMC compensate by moving things around like the heavy
porpane tank over to the othersibe to balance a full water tank? Phil in
Bonita your 23 didn't come with gen set. What was your layout. Anyone else?
Finally, Chuck, Phil, Lyn, and anyother San Diego GMCers on list, any
interest in sharing the cost on the wheelbearing puller? I see Chucks
already on the list. How about it guys and gal?????
Arden 73 Sequoia
