I'd vote for a low quality fitting.
It should be near impossible to ruin a fitting during installation, youd have to really work at it.
Then again, I have see what the PO thinks is correct....
> From: sgltrac
> Date: Sun, 9 Oct 2016 15:59:38 -0700
> To: gmclist
> Subject: Re: [GMCnet] Powerlevel in early '76
> I suppose a fatigue failure of a shut off / schrader valve set up is
> possible but I suspect a failure like Ken reported is more likely the
> result of a fitting which had been weakened by some other prior event
> , improper installation or debris kicked up from the roadway. I also
> believe that the cause when being marooned by the rear suspension system is
> far more likely to be a failure of the 40 year old compressed air system,
> plumbing and assorted electrical controls than a newly installed schrader
> and ball valve set up.
> My 2c
> Sully
> 77 eleganza2
> Seattle
>> The combined weight of the shut off valves hung out a good ways from the
>> bag, almost insures some bouncing. Bend anything back and forth enough
>> cycles and failure is immenent. Best way is to mount the shut off valve and
>> Schrader valve on a manifold and attach it to the wheel well high and out
>> of the way of a blowout. Then just plumb the air line to the bag. Ez-Pz.
>> Jim Hupy
>> Salem, Or. (Presently at Coos Bay, Or. In bright sunshine. No breeze at
>> present. GMCWS multi club rally)
>> On Oct 9, 2016 2:55 PM, "Ken Burton"
>>> You are going to love those valves until one of them breaks off flush
>> with
>>> the bag.
>>> I had blacklist call from a young lady one day that said her air bag
>>> blew. When I got there the bag was fine but the pipe between the bag and
>>> the
>>> valve broke from bouncing up and down with the extra weight of the valve
>>> hanging on it. It was not a fun day as I could not get the broken pipe
>> out
>>> of it on the road. Also bag mounting nuts were rusted badly. I ended
>> up
>>> calling a buddy to bring out a flame wrench to use on both of the nuts.
>> We
>>> took the bag to the shop to remove the broken pipe.
>>> We reinstalled the bag with new stainless nuts, stainless tooth washers,
>>> and anti-seize but WITHOUT the shutoff valve. We also removed the other
>> one
>>> from the other side.
>>> It was not a fun day working on that thing along the Interstate.
>>> I would not have those valves anywhere near my coach. Fix whatever is
>>> wrong with the air system and get rid of those shutoff valves. I do
>> carry a
>>> pair of schrader valves to use in an emergency, but I have never needed
>>> them.
>>> If you use them you are crippling your automatic air adjustment system
>> and
>>> introducing another possible failure point.
>>> Ken Burton - N9KB
>>> 76 Palm Beach
>>> Hebron, Indiana
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
