Cheech Zak, now you've given me more stuff to research in preparation of
Onan/Honda switch
When/where will it end [g].
Seriously, I'm not sure how mine wired other than the switchover being
automatic and since my relay was still good I didn't worry about it too much
and as my Onan is now dead alltogether I havn't had the chance lately.
Thanks for bringing it to my attention.
Richard, as far as what Camping World sells, no idea. I bought them from Jim
Bounds by just telling him my needs. I too plan to use the GenSet as
emergency housepower once I get the Honda installed.
Heinz
>Heinz,
>The capacity might not be as important as how it handles the circuits. The
>GMC wiring is set up so that it gets two feeds from the 6K Onan. It gets
>one 30 amp feed and one 20 amp feed. The 20 amp feed is mostly for the A/C
>and some small appliances, while the 30 amp feed is mostly for everything
>else. These circuits are kept totally separate. Even though our 23' came
>with the 4K Onan which only provided the 30 amp service, it was still wired
>for the separate circuits which made installing the 6K Honda much nicer.
>I believe that the 50 amp transfer switch would keep them separate, but the
>30 amp one would combine them. I suspect this is why the 50 amp one is so
>much bigger. Do you know if this is true? I don't know if it would be
>good to combine the two outputs of the Onan or not. I suspect, serious
>problems could arise if you inadvertently got close to the 50 amp draw with
>it set up like this. It might be easier to exceed 30 amps than you think.
>With the A/C and Microwave on we would trip our 20 amp breaker. If you add
>the converter's 7 amp draw or so, we were definitely higher than 30 amps
>total. We have now moved everything over to the 30 amp service except for
>the A/C and have not had any further problems.
>As a side note, one of the adapters used only when plugging it into shore
>power does combine the two circuits together so they both get power when
>hooked to a normal 15-20 amp outlet. In this case, however, the shore
>power's breaker is expected to limit the current to acceptable levels.
>Zak
>>Richard,
>>I got a TS-30 and TS-50 from Jim Bounds last year. I actually only used
the
>>time delay module as my Transmode has a switch-over relay similar to
what's
>>used in the TS's already installed. ( The rest is now 'spare parts').
>>The TS-50 is large physically. Unless you have 2 AC's I would guess that
>>you'd never draw 50 amps when running on the GenSet.
>>The TS-30 may be ample for normal needs and is much easier to install.
>>The scheme of it is that by default, i.e. relay de-energized, the contacts
>>are closed to shore power. When GenSet is started the output is sensed by
>>the time delay and after a short time the relay is energized and coach
>>switches to GenSet power. The time delay is sufficient for the GenSet to
be
>>stable before relay is energized.
>>It would be a simple retrofit as it's all in it's own enclosure.
>>If you need some measurements on the enclose, let me know.
>>Heinz
