Power Steering Pump
les & des
57
We have an iteresting one for you guys.
Our motorhome has been parked since October besides the last of
January when we had a couple of tires replaced. The last time it
was started was February 11th when we did an oil change. (yes,
Mobile 1 15w50. We have been synthetic for several years.)
Anyway back to the situation. About two weeks ago we noticed a
puddle of what looked like transmission fluid. It seemed to grow,
so when we had decent weather, we got under the motorhome to
try to locate the source of the leak. It seemed to be coming from
the area of the power steering pump, so we decided to check the
ps fluid. It was overfull and when we took the cap off, more spilled
out. That seemed to be the source of the leak. Since then,
nothing else has been noted. Some other factors: The GMC is
parked on a slight incline with the nose a little lower than the tail
(the airbags are fully deflated, but the back end is on blocks.
We've had a few bouts of single-digit weather followed by
temperatures in the 40's or 50's.
Any ideas? Anything we should worry about?
Thanks for your help and input.
Les and Des
73 Painted Desert
Rocky Mount, NC
mailto:lpraisee
vist us at: http://www.livingpraise.org
Has anyone found a power steering pump available from local autoparts
stores? I have checked several (autozone, napa, etc) and no cross to
the GM PN. A-1 is a major rebuilder and I may send the orig off to be
rebuilt. Perhaps someone has been down this trail allready. If
necessary I can always get one from the GMC suppliers or try to
rebuild myself. Mostly a leak problem out the back.
BTW I crossed the Goodyear upper radiator hose PN someone posted to an
Autozone one (shaped hose not flexible), I'll report on the fit after
installing.
Thanks,
Bill
'74 Glacier
DO YOU YAHOO!?
Bill,
No problem, the PS pump is available locally. You have to answer a
question though. There are to pumps used, one has a shaft for the pulley
to fit on and the other uses a bolt. One is an "innie" and the other is an
"outie". You have to replace yous with the right one to allow the pulley to
fit.
Give me a call at work tomorrow and I'll give you the #'s, my parts data
base is at the shop and I am at the house right now.
Hope this helps,
Jim Bounds
>installing.
>Thanks,
>Bill
>'74 Glacier
>DO YOU YAHOO!?
Jim Bounds / Co-op Motor Works Orlando www.gmccoop.com
Another thing that you might consider is that the pump itself is generic to
GM; only the sheet metal can differs with application. Well, actually, the
regulator is specific too, come to think of it. And the pulley might be
different as well.
But the pump is extremely easy to find. Get one off of a Chevy pickup or
whatever, then move your can from your defective pump to the replacement. If
the pulleys are different, use your old one. The outlet fitting contains the
regulator, so use your old one.
The only other caveat is that some of the later pumps had metric
fasteners...If you run into this, you'll want to keep the fasteners with the
right pump.
This is no different from using the CV joints off of an Eldo or Toro...the
shafts are different, but the joint itself is the same.
Travis, lurker
- -----Original Message-----
To: gmcmotorhome
Date: Sunday, March 21, 1999 9:02 AM
Subject: Re: GMC: Power Steering Pump
>the GM PN. >>
>Whenever I can't find a match to the GM part numbers I tell them to look up
a
>1976 Olds Tornado with a 455 V-8 and most of the time its a direct fit. I
>haven't done this with the power steering pump but would be interested in
what
>you find by doing this.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Just a word of caution about a "generic" steering pump. Although pumps look
alike, they can have big differences in the top pressure they'll produce.
There's an internal relief valve that determines the maximum pressure. I don't
know this for a fact, but I suspect that the higher load on the front tires of a
GMC leads to a higher pressure requirement than a pick-up. If the pump pressure
setting is too low, it's liable to burn out quickly if the relief valve pops off
during normal turning.
Clark Searle
78 Kingsley
Mt. Pleasant, MI
> different as well.
> right pump.
> Travis, lurker
> From: EMERYSTORA
> To: gmcmotorhome
> >the GM PN. >>
> a
> what
> >Emery Stora
> >77 Kingsley
> >Santa Fe, NM
True, but the relief valve is in the outlet fitting...thus I recommend that
you keep your original outlet fitting when you change pumps.
Travis
To: gmcmotorhome
Date: Thursday, March 25, 1999 9:19 PM
look
don't
of a
pressure
pops off
>Clark Searle
>78 Kingsley
>Mt. Pleasant, MI
to
the
>> different as well.
If
the
the
>> right pump.
Toro...the
>> Travis, lurker
>> From: EMERYSTORA
>> To: gmcmotorhome
>> >the GM PN. >>
up
>> a
I
in
>> what
>> >Emery Stora
>> >77 Kingsley
>> >Santa Fe, NM
I kinda doubt that, but I'd at least suggest verifying that the relief valve is
in the outlet fitting. A relief valve operates by bypassing the oil within the
pump from the high pressure side to the intake side. The main purpose is to
protect the pump as well as the system from over pressure. An in-line valve
would need a passage to bypass the oil back to the inlet side of the pump. That
certainly is possible, but I'd recommend verifying this situation before
switching pumps.
Clark Searle
78 Kingsley
Mt. Pleasant, MI
>> Travis
>> From: Clark Searle
>> To: gmcmotorhome
>> look
>> don't
>> of a
>> pressure
>> pops off
>> >Clark Searle
>> >78 Kingsley
>> >Mt. Pleasant, MI
>> to
>> the
>> >> different as well.
>> If
>> the
>> the
>> >> right pump.
>> Toro...the
>> >> Travis, lurker
Trust me, Clark, I've done more than a couple. The relief valve is part of
the outlet fitting. It screws into the pump body about an inch and a half;
has a spool valve and spring to bypass over pressure.
Back when I used to autocross Corvettes, we used to change the relief
valve/outlet fitting assembly for one from a 3/4 ton Chev pickup because the
stock Corvette relief valve had a smaller discharge orifice and would
sometimes "back up" if you were turning back and forth rapidly (as in a
slalom).
Is there not an exploded view in a manual?
My point is that GM, like any successful mass producer, standardized as many
parts as possible across its lines for best economy of scale. Thus the
steering pump is pretty much universal to any GM product from the era, with
the variations being accommodated by the bolt on parts--primarily the
reservoir (can), in some cases the pulley, the relief valve/outlet fitting
assembly, and, of course, the mounting brackets.
If you will simply pick one up and look at it I think you will see what I
mean.
Travis
To: gmcmotorhome
Date: Saturday, March 27, 1999 11:13 AM
valve is
the
to
valve
That
>switching pumps.
>Clark Searle
>78 Kingsley
>Mt. Pleasant, MI
that
>>> Travis
>>> From: Clark Searle
>>> To: gmcmotorhome
>>> look
produce.
I
>>> don't
tires
>>> of a
>>> pressure
>>> pops off
>>> >Clark Searle
>>> >78 Kingsley
>>> >Mt. Pleasant, MI
generic
>>> to
actually,
>>> the
be
>>> >> different as well.
or
replacement.
>>> If
contains
>>> the
with
>>> the
>>> >> right pump.
>>> Toro...the
>>> >> Travis, lurker
Actually, the outlet fitting only has the flow control orifice in it. The
relief valve is a spool valve that slides in the bore that is in line with the
outlet fitting. They are two separate parts. I verified this by looking at the
GMC Service Manual. Nevertheless, if you switched the spring, spool valve and
outlet fitting, you would maintain the original flow and pressure setting. I
believe the pulley is another concern. Ours is a double shieve pulley pressed
onto the shaft. You would need to retain the dual belt drive and same pulley
diameter.
And trust me, I've got a couple patents on power steering pump design.
Clark Searle
78 Kingsley
Mt. Pleasant, MI
> slalom).
> mean.
> Travis
> From: Clark Searle
> To: gmcmotorhome
> valve is
> the
> to
> valve
> That
> >switching pumps.
> >Clark Searle
> >78 Kingsley
> >Mt. Pleasant, MI
> that
> >>> Travis
> >>> From: Clark Searle
> >>> To: gmcmotorhome
> >>> look
> produce.
> I
> >>> don't
> tires
> >>> of a
> >>> pressure
> >>> pops off
> >>> >Clark Searle
> >>> >78 Kingsley
> >>> >Mt. Pleasant, MI
> generic
> >>> to
> actually,
> >>> the
> be
> >>> >> different as well.
> or
> replacement.
> >>> If
> contains
> >>> the
> with
> >>> the
> >>> >> right pump.
> >>> Toro...the
> >>> >> Travis, lurker
