> Success!! I bought Northern Tool set for pulley removal. Heated and quenched with PB blaster a few times. Watched the utube videos, including the
> guy that ruined his pulley. I had to use my electric impact wrench but it finally came off. Thank you everyone for your ideas and information. Now I
> have to wait for delivery from Applied.
> Are there any secrets to getting the air out of the system?
Most importantly is did the removal tool come with an installation tool? The pulley must NOT be pressed onto the pump shaft, or the new pump will be
damaged. It has to be drawn on, using the threads inside the shaft. Usually a long threaded stud with a bearing plate or some flat washers, and a nut
to draw the pulley down onto the shaft. Worked at auto parts stores for years, saw quite a few pumps come back damaged from pulleys being pressed on,
or even worse, hammered!
John in Omaha, Nebraska
74 26' Sequoia
74 26' Sequoia
